Has anyone ACTUALLY performed the AOD swap of Danny Cabral's??
I am wanting to install an AOD in my 79 4x4 Supercab and wondered if anyone has ACTUALLY performed this swap?? My concern is the transfer case. Danny talks about it in his article. Does it really work?? I have read the article several times but am still uneasy about the transfer case situation. Please give me any tips if you have performed this AOD swap.
Thanks
Thanks
Hi bareaneye,
What exactly do you need clarification on? I think my article is very detailed in reference to the NP205 transfer case. You must also reuse the transfer case side mounting support (brackets & bushing).
Feel free to ask questions. Although, if you're serious about performing this overdrive transmission conversion, I highly suggest, you call me (to discuss other conversion specific details).
Lentech Strip Terminator AOD with 460 stroker. - 460 Ford Forum (most recent info)
Complete Overdrive Conversion for '78-'79 Ford Bronco .: Articles (original article)
May God's Grace Bless You
'78 BRONCO: 508" stroker, TFS heads, Dominator MPFI, DIS, A/C, Lentech Strip Terminator wide-ratio AOD, 3:1 Atlas II, modified Dana 44/60-lockers-4.10s, hydroboost/4-disc brakes, ram-assist/heim-over steering, Cage long radius arms, 4" lift, 35" tires
Hi bareaneye,
I don't have "messages" enabled on this forum.
So email me direct; my email address is below.
Danny Cabral
d c f 1 5 0 @ c o m c a s t . n e t
Danny Cabral
ssanto
06-29-2006 06:54 AM
