Question for Transmission Engineer or Transmission Master Tech
Old 08-26-2012, 09:33 AM
Beechkid's Avatar
Beechkid
Beechkid is offline
Hello & Thank you in advance!
I have a 2006 Mark LT 4x2, 5.4 V8....here is the situation..
In Los Angeles we have a lot of multi story parking structures with speed bumps....I typically place the truck in 1st, maintaining a speed of 5-8 mph to travel up and down in the structres (which I visit often)....to avoid the constant shifting of the trans (1-2) and use of the brakes (the speed bumps are not of a DOT approved type and typically require reducing speed to almost zero).
Here is the question.....
My neighbor (a mechanic) is suggesting this is "hard" on the tranny and could/will reduce the life of the 1st gear components, IMHO, I think the opposite......and the winner is..............
Old 08-26-2012, 05:47 PM
70f100longbed's Avatar
70f100longbed
70f100longbed is offline
Nope your neighbor is wrong. When the selector is in 1st the low/reverse band is applied in addition to the low one-way clutch, that's why you have engine braking in manual 1st. When in drive only the low one-way clutch holds for first gear. Manual 1st is stronger than 1st gear in drive.
Old 08-26-2012, 10:29 PM
Beechkid's Avatar
Beechkid
Beechkid is offline
Thank you...I figured auto's haven't changed in that manner in the past 40 years or so......it may generate a little higher oil temps but the absence of braking and the tranny shifting 1-2 & 2-1, is surely a "better thing"
He's young & trying hard (the neighbor mechanic)
Old 08-26-2012, 10:36 PM
Tylus's Avatar
Tylus
Tylus is offline
MMNC (SS)(Ret)
Putting the selector in 1-3 also remaps the throttle. You get approx 50% of normal throttle, but the gain is turned way up. Much more sensitive and ability to fine tune speed/power to wheels
But yeah, putting her in first does no harm.
Old 08-27-2012, 01:05 PM
Beechkid's Avatar
Beechkid
Beechkid is offline
Thank you!
Old 08-28-2012, 11:07 PM
Papa Tiger's Avatar
Papa Tiger
Papa Tiger is offline
Temporarily Deactivated
Received 3,425 Likes on 2,340 Posts
Using tow/haul if you have it would be similar.
e30rik
06-11-2017 11:23 AM
1959_f100
11-08-2008 06:42 PM
matt2491
13
02-17-2008 11:02 PM
Fordgery
10-12-2007 12:01 AM
4.2W/GEARS
03-18-2004 05:04 PM
Quick Reply: Question for Transmission Engineer or Transmission Master Tech
