mating a 429 to a ZF
Old 08-26-2012, 05:20 PM
choptop49ford's Avatar
choptop49ford
choptop49ford is offline
putting a 429 in dads 79 F350 4x4 super cab and he pulled a ZF that he wants to mate it to. he has a stack of fly wheels including a 429 mach 1 flywheel with 0 balance but he is concerned because it is a different diameter and tooth than the 460 flywheel that was with the ZF. what is the best route to go? have the weight cut off of the 180 tooth ZF and rebalance it to 0, or is there a cheaper, easier option?
Old 08-26-2012, 11:05 PM
85e150's Avatar
85e150
85e150 is online now
Received 1,595 Likes on 1,300 Posts
Where did the 429 come from?
Old 08-27-2012, 07:27 AM
choptop49ford
He pulled it from a large 68-69 car. He couldn't remember but it was an automatic so no flywheel. The only 0 balance flywheel he has for it is a different diameter and tooth count than the flywheel that came from the zf. Can't we just use the 0 balance mach1 flywheel and a matching starter?
Old 08-27-2012, 07:26 PM
85e150's Avatar
85e150
If you can bolt on the right size pressure plate, that should work.
Old 08-31-2012, 08:58 PM
UNTAMND's Avatar
UNTAMND
UNTAMND is offline
Umm
Rebalance the 460hd flywheel. The clutch on the zf is metric spacing and I think slightly larger. Way easier that way. A different diam flywheel won't work because starter location will be wrong.
Pilot shaft bushing in a 429 is smaller also. You'll need to try one from a 70-73 mustang to see if it fits in the end of crank. A 460 one won't fit.
429poweredf350
05-17-2009 09:59 PM
justforkicks
04-01-2009 12:12 PM
chrepy
03-25-2006 11:31 PM
frederic
03-16-2004 11:27 PM
Quick Reply: mating a 429 to a ZF
