Last edit by: IB Advertising
See related guides and technical advice from our community experts:
Browse all: Electrical Guides
- How to Replace Your Alternator
Step by step instructions for do-it-yourself repairs
How to change a 460 alternator v belt?
I feel pretty dumb here. My Alternator belt broke, and I've removed the remaining belts, since the alt belt must go on first. but for the life if me can't get the new v belt around the crank pulley. The fan pulley is just too close.
Is there some magic solution I just don't see?
Thanks,
Mark
Thanks,
Mark
Damn it! I was searching and thought I found the right thread and then the OP solved his own problem. Well, I'll be the dumb one again. I have an FE and i'm trying to anticipate problems, such as bad belts. I'm pretty new to old vehicles, and I don't see a tensioner to replace the v belts. Do I just muscle them on? is there a trick?
I want to take them all off and go to NAPA to get new back up ones in case I need them in a pinch.
thanks,
thanks,
It's the same way with my golf game. Just enough beer helps me relax and hit the ball better. Too much and I get sloppy. So, I keep experimenting to find just the right balance...............
Of course yesterday I was having a brew and working on recurving my distributor. Got it all back together but then the truck wouldn't fire. finally realized the rotor was still sitting on the fender well.
thanks,
thanks,
The alternator pivots to loosen and tighten the belt.
Crank-water pump- alternator
Crank-power steering seperate belt
Josh
A properly sized belt fits within the pulley groove, not protruding or riding on top of it... if it does then it is actually too wide or the pulley too narrow.
thanks,
thanks,
Alternator-loosen the nut on the slotted adjusting arm, then loosen the bolt that holds the alternator to the block. Push the alternator towards the water pump to loosen the belt.
Power steering-Loosen the three nuts on top of the pump that holds the pump to the bracket. Back off the nut on the outside stud that slides the pump to tension the belt. Push the pump in to loosen the belt.
Factory A/C-Loosen the two bolts on the top idler pulley, one is a pivot bolt and the other is in a slot that allows the idler pulley to swing and tension the belt.
I would suggest you invest in copies of the FACTORY service manuals and parts catalogs. These are available on CD and are invaluable when working on the trucks. I use my copies constantly.
You didn't specify which engine so this is kinda general.
Josh
Gotta remember, guys, some of the folks coming here now are young enough that they haven't known vehicles without serpentine belts and spring tensioners. One of my nephews is mystified by the dimmer switch being mounted on the floor. How many here know how to work a floor starter or have even heard of one?
But you're right. People that are the under 30 or so crowd have never had to deal with V-belts, carburetors, points, engine mounted fuel pumps, etc.
That's why, when I see a question like that I try to answer it honestly.
All of us were "newbies" at some time in our lives.
Thanks for all the help. Mike hit the nail on the head: I'm 30. I understand all the concepts, and even worked at a diesel mechanics shop in my youth, but that was many years ago. Also, while someone may understand concepts, it is sometimes the smallest things, like belts, that give people trouble (think of an engineer who designs versus the mechanic who repairs-things on paper don't always pan out in the "real world").
Nevertheless, I greatly appreciate the help and have already thought about investing in the repair manual and as I was typing this reply I was trying to remember from my youth whether Chilton's or Hayne's was better. IIRC, it's Haynes,, though I'm confident either will work for a newb like me.
Thanks,
Trip
Thanks,
Trip
Thanks,
Trip
Thanks,
Trip
