What did you do to the Bronco Today?
#3316
Sorry for the slow reply. Been without power and phones since the hurricane rolled thru here! The seats came out of a 90's plain jane Bronco. Definitely not as much padding as my XLT seats! Gonna keep them in there till I get my seats redone. For the money, they were a good buy!
glad you are ok and back on line
#3318
My Bronco starter quit last winter, figured I would hit the starter to move it to a better, dryer spot, no dice.
#3319
We opened the old starter on the parts counter to see what it looked like (the girl and I had never seen the guts before) and it looks like I busted one of the magnets when I banged on it
The brushes were toast, smelled real bad when we cracked it open and was really black inside.
Left the phone in the Bronco (actually it fell out of my pocket and landed under it) so no pics
#3320
#3321
Interior still looks good in it too. Hard to find one without the dash pad cracked too. Congrats on the new purchase!
#3322
I've done a bunch of work over the last few weeks. I'll try to list it all out.
New SS Brake Lines, New brake hoses, New Master Cylinder, New rear wheel cylinders, New calipers, New rear drums & brake shoes & hardware, New drilled and slotted rotors & pads.
New Front driveshaft U-Joints, New front axle U-Joints, New ball joints, New Poly axle pivot bushings, New poly radius arm bushings.
Cleaned and repacked front wheel bearings with all new seals. New rear axle seals, New Ford Racing LSD carbon clutches.
New rear tail lights with retro-fit LED bulbs, LED bulbs in high mount brake/cargo light.
After the front end alignment and seating in the new brakes, I'm just about ready for the winter season.
#3324
#3325
#3329
#3330
A week or so ago I switched out the old rims and tires for some old junkyard rims I cleaned up and some new tires. Also new is the front u-joints and shaft bearings. I also fixed my stereo ground wire today. Now, I can crank tunes again. She's finally coming together from an old derelict POS.
