What did you do to the Bronco Today?
#616
Thanks folks.. just dropped Angus off for 2 new front tires.. going with General Grabber AT/2 in standard size 31x10.5Rx15LT.. was quoted $160 each mounted and balanced.. considering most places want about $150-160 not mounted from on the web... after I pass NJ inspection I'll be doing 2 more for the rear.. then the shocks, stabilizer, radius arm bracket, etc..
Original tires are the Michelin XC LT4's... which are from at least 2006 (last inspection date).. and have slices in the sides.. and just old..
#617
#620
#623
#624
Finished modifying the adapter plate for the A/C compressor, and the compressor is in it's new house now, lots of HNBR o-rings in place and I'm almost done. The engine belt was a 94" but now I think I'll need a 92" (with this the truck will be operational once again, given that the new plate/compressor pulley is properly aligned), I guess I'll find out tomorrow, oh, and then condenser I have won't fit... it's too long at 28", it requires something around 24" measured from the mounting holes in one side to the holes in the other. Also found out the idiots at the trans shop hooked a transmission cooler to my trans but disconnected the radiator cooler in the proccess, so there was basically no gain...
#626
I put 2 out of 3 quarts of oil in TGM today, along with some gas.
There was no oil touching the dipstick and the oil pressure was oddly low on startup so I dumped 2 quarts in. It isn't full yet but it's enough to have good pressure. I have a truck meet with a few other FTE members tomorrow and I have a custom PC being built that I need to go pickup so I had to get a bit more gas in the tank. I also took the truck off road into this little muddy area that has a lot of... Speed bumps? And I think I got the rear tires off the ground, or very close. It was pretty fun.
#627
#628
Started to pull the steering box and power steering pump. Pump is constantly noisy and steering gear is leaking again. I figured it was worth a shot trying the Lucas powering steering stop leak and conditioner. It stopped for a while, but is leaking just as bad now as when I towed it to my driveway! I'm not much for "mechanic-in-a-can" products, but Lucas makes some good stuff! I swore by them in my dump trucks! I'd like to get a Red Head steering gear but it's not in the budget!!
#629
#630
