What did you do to the Bronco Today?
#3436
#3438
#3439
I went right back at trying to start my Bronco after I abandoned it for 2 years. I was too tired of fixing things so I bought a 2002 Mitsubishi Montero with low miles which has been a blessing so far, little to no issues. Finally made a breakthrough and found the problem is caused by a failure in the fuel delivery system. In the following days I'll try replacing the fuel pump with a whole Motorcraft assembly, and will have a look, maybe replace the Fuel Pressure Regulator too. Tried a Bosch fuel pump and new filter (the original one was completely clogged) to no avail. I'm suspecting one of the fuel lines might be clogged somehow.
#3440
Had a hot restart issue. Pulled the Ignition Control Module (ICM) to clean the back and reapply the heat transfer grease. It seams to have helped.
Last week I got the following done:
New tires mounted and balanced on reconditioned stock allow rims. Installed on Bronco.
New front brake pads.
Changed front axle gear lube.
Changed transfer lube.
#3442
I've done a lot to the Bronco since the last time I reported in. Got new ball joints and tie rod ends installed. New Kumho Road Venture 32s installed and a BFG All Terrain for a spare. Taught my little brother how to wax up the truck in preparation for the local car shows. Kinda hard to believe that technically it's an "antique".
Preparing to install a slightly larger exhaust and a flowmaster we've had sitting around for a while. I want to punch out cats but dad won't let me - he doesn't want to pollute more than we have to.
#3443
#3445
#3448
installed a new stereo w/dvd,.and some speakers,.weird that,.there is a wire they want you to hook to your parking brake light, so you wont watch dvd's while driving,.,LOL I grounded it and it works just fine while driving, LOL (mobile ****),.but really i'm getting a dvd monitor for the back for camping and such,.it works good and for a 3.5" screen its really clear,.
Do you have any photos of before/during/after?
How much of the radio bezel did you cut, etc...
#3450
Mr. "I Hate Fords" (my pops) needed to borrow my truck today. His '07 DMax is down with a tensioner pulley issue and his '99 Tahoe is no longer insured or plated. We needed to get a 1/2 load of crushed gravel in a 14 ft dump trailer about 5 miles to my house. The only other vehicle with a receiver hitch is the old '88. Dad spent a day installing a brake controller and 7-way plug, and this morning we picked up the trailer. Wish I would have gotten pictures - the old man was squatted down but was able to move and stop the load just fine.
Let it be noted: I will never endorse towing ANYTHING with our Bronco other than the 6x8 utility trailer we have but this time I let curiosity get the best of me. Also worth noting that the "ford hater" has nothing but good things to say about the Bronco: "it's the only ford I'd buy", "the 351 is a good strong engine", etc..... He told me today that he actually bought a brand new 1989 Eddie Bauer and pulled a boat with it back in the day. Ford hater... yeah right.
