What did you do to the Bronco Today? - Page 226 - Ford Truck Enthusiasts Forums
1978 - 1996 Big Bronco
  #3376
Old Yesterday, 09:51 AM
MadMatt65's Avatar
MadMatt65 MadMatt65 is offline
MadMatt65 has a good reputation on FTE.MadMatt65 has a good reputation on FTE.MadMatt65 has a good reputation on FTE.
Got the Bronco all back together. Cost a bit more than I wanted to spend........but I guess that's par for the course on a 25 year old vehicle!
New head gaskets, all upper gaskets, distributor, new Motorcraft wires, cap and rotor, spark plugs, fuel injectors. Fixed some of the vacuum lines.
Running good!!
  #3377
Old Today, 03:07 PM
MadMatt65's Avatar
Got the Bronco all done but had the chirp, chirp, chirp of the serpentine belt. I noticed the Motorsports air pump delete pulley wasn't quite lining up right. Causing the belt to ride one rib off the crank pulley. re-routed the belt as pictured and no more chirp! It was a 97" belt. A bit tight, but finally got it on!!
What did you do to your Super Duty today? ufvj217 1999 to 2016 Super Duty 1057 Yesterday 06:19 PM
What would make the best family hauler fun rig? F350moneypit 1973 - 1979 F-100 & Larger F-Series Trucks 25 01-03-2018 02:11 PM
Why did you pick a Bronco? greystreak92 1978 - 1996 Big Bronco 128 01-02-2018 07:44 PM
My 95 bronco idi build Jay54 Pre-Power Stroke Diesel (7.3L IDI & 6.9L) 21 05-08-2017 04:07 AM
Project Thunderhorn: Second Generation Bronco Build Thunderhorn 1978 - 1996 Big Bronco 68 02-06-2017 02:19 AM
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
