What did you do to the Bronco Today? - Page 224 - Ford Truck Enthusiasts Forums
Go Back  Ford Truck Enthusiasts Forums > Bronco > 1978 - 1996 Big Bronco
Reload this Page >
  #3346
Old 12-31-2017, 11:18 PM
ZombieSlayer's Avatar
ZombieSlayer
ZombieSlayer is offline
ZombieSlayer has a good reputation on FTE.ZombieSlayer has a good reputation on FTE.
I drove it around the block once. I now have a 2016 Fusion that is my DD. The Bronco will be sidelined while I save up a buck here and there to fix her up.
  #3347
Old 01-02-2018, 12:57 AM
khadma's Avatar
khadma
khadma is offline
Carpenter Local 745
khadma has a brilliant futurekhadma has a brilliant futurekhadma has a brilliant futurekhadma has a brilliant futurekhadma has a brilliant futurekhadma has a brilliant futurekhadma has a brilliant futurekhadma has a brilliant futurekhadma has a brilliant futurekhadma has a brilliant futurekhadma has a brilliant future
PMed Conanski about camshaft information, I got great information, now I just have to locate some valve springs that will work with the new camshaft.
Thatʻs about all I did for the Bronco lately.
  #3348
Old 01-02-2018, 09:35 AM
AKraider
AKraider is offline
AKraider is starting off with a positive reputation.
Talking Excuses
Originally Posted by chrlsful View Post
no need unless improperly maintained - 1/2 way there right now...
ck the FW teeth as the starter looks like they both got in a fight.
Just fix that rather than a rebuild...
She is not in need of a rebuild but something has to come out if I were to change the flexplate. I cleaned up the damage with a file prior to installing the new starter, she sounded fine on test cranks. If I change the flex plate out I might as well pull the motor and church up with overbore heads cam and maybe a stroker kit. Just fresh motivation to see what parts are out there and try to throw a budget together for it.
  #3349
Old 01-02-2018, 08:32 PM
JRE_96Bronco's Avatar
JRE_96Bronco
JRE_96Bronco is offline
JRE_96Bronco is starting off with a positive reputation.
fire fighter?
Me?
Nope, accountant.
Why do you ask?
  #3350
Old 01-12-2018, 07:11 PM
rickmad
rickmad is offline
rickmad is starting off with a positive reputation.
I'm new here but I did just put in a new heater core
  #3351
Old 01-12-2018, 08:17 PM
mecdac's Avatar
mecdac
mecdac is offline
If it flies, it dies
mecdac has a superb reputationmecdac has a superb reputationmecdac has a superb reputationmecdac has a superb reputationmecdac has a superb reputationmecdac has a superb reputationmecdac has a superb reputationmecdac has a superb reputationmecdac has a superb reputationmecdac has a superb reputationmecdac has a superb reputation
  #3352
Old 01-12-2018, 10:21 PM
chrlsful's Avatar
chrlsful
chrlsful is offline
chrlsful has a good reputation on FTE.chrlsful has a good reputation on FTE.chrlsful has a good reputation on FTE.
Thanks for the post-back.
Originally Posted by JRE_96Bronco View Post
Me?
Nope, accountant.
Why do you ask?
I See "Black Helmut"
  #3353
Old 01-26-2018, 11:28 PM
Black Helmet's Avatar
Black Helmet
Black Helmet is offline
Black Helmet is gaining momentum as a positive member of FTE.
fire fighter?
Yessir!
Originally Posted by McLeod View Post
Nice looking Bronco.
The very first thing I noticed about your picture though is the look of the background subjects: I knew what specific general region you where at, and after seeing your other photos, I probably could guess what exact subdivision you live in.
Once upon a time I was over on Peachtree.
Small world it is.
Anyways.... awesome truck!
That is pretty wild! Peachtree (as you know!) is only a couple miles by road and less as-the-crow-flies from my front door!
& i picked apples in Wahnatchee (1978)
Another spot not too far away!
  #3354
Old 01-27-2018, 12:11 AM
ZombieSlayer
Found out that my seal from the top leaks somewhere down the side pillar on the passenger side. Think I could get away with injecting some silicone into the seal via a syringe to "fatten" it up until I can replace it?
  #3355
Old 01-27-2018, 12:37 AM
McLeod's Avatar
McLeod
McLeod is offline
McLeod has a good reputation on FTE.McLeod has a good reputation on FTE.
Sure it's the seal and not the roof gutter leaking?
The top actually has two seals where it meets the cab
  #3356
Old 01-29-2018, 12:27 AM
ZombieSlayer
Not 100% but about 90% sure it's the seal. The gutter looks good, no rust, nor holes. I suppose it could be the weather strip but the water comes from the area below the pop out ashtray and drink holder.
  #3357
Old 01-31-2018, 12:07 AM
SDDL-UP
SDDL-UP is offline
SDDL-UP is starting off with a positive reputation.
Well... I'm in the middle of a front end rebuild on my 78 Bronco and finally replaced a busted front axle U-joint. Two new Spicer 5-760X U-joints went in today. The eight main C cap bolts are all that's left before I drop the axle housing out and can begin clean-up on that.
  #3358
Old 02-05-2018, 12:35 AM
Black Helmet
Installed LED headlight conversion, tinkered with a coolant and trans fluid leak (hopefully stopped for good!) and washed it off.
  #3359
Old 02-06-2018, 09:32 PM
diymirage
diymirage is offline
diymirage is starting off with a positive reputation.
had the piece of junk towed to my mechanic again
somehow it lost spark
its a good think michigan is so flat or i'd find a nice cliff to kick her off
  #3360
Old 02-13-2018, 05:39 PM
BaronVonAutomatc's Avatar
BaronVonAutomatc
BaronVonAutomatc is offline
BaronVonAutomatc is gaining momentum as a positive member of FTE.
Replaced the sealed beam headlamps with Hella housings and H4 bulbs
Quick Reply: What did you do to the Bronco Today?
Contact Us About Us Archive Advertising Cookie Policy Privacy Statement Terms of Service
© 2018 MH Sub I, LLC dba Internet Brands
