What did you do to the Bronco Today?
#1906
I checked fluids today. Was about 1/2 quart low on oil. Not too bad since its been 6 months since oil change. Before any1 goes all freaked out about that,I use mobil1 synthetic. Good for 15,000 miles or a year.Tranny was about the same. I have a small leak between tranny/transfer case. I'll live with it for a while. I have a brake fluid leak I have never run into before. It is leaking out the master cylinder cover. Has a new master cylinder and I changed gasket on it about 2 months ago. I am not sure if brake booster would have anything to do with that or not. That is the only major component that isnt new. I have never run into a master cylinder pushing fluid out like this. If it continues I will pull it off and exchange it. Probably should have went with a raybestos instead of damn duralast.
#1907
#1908
#1909
#1910
I have cheap oil in mine, but it has only been in for 3 months, and maybe 1,500 miles. When I put an additional 4,500 miles on it, I'll change it. Of course, I checked it the other day and it was 2 quarts low, so maybe I will just change the filter in another couple of months, and keep adding oil to it. LOL
Jim
Jim
#1911
My truck is regularly 1.5 to 2.5 quarts low, and I haven't changed the oil in about a year I'd guess. Sure some may say I don't care about truck or something like that but you'd be wrong. I'm just now on my feet with a job and there are other pressing matters that need my attention before an oil change. Chances are ill probably get around to it in summer or spring.
#1912
Since mine seems to be leaking it at a rate of a quart a month, I see no need to change my oil since it does it by itself, so I will just change the filter every 6 months and continue on my way. It is not burning it, which is a surprise considering it has 240k on the odometer. Of course, I have no way of knowing if this is the original engine or not.
Jim
Jim
#1913
#1919
Driver's Seat Repair
Driver's seat was sitting in my garage so I decided to see how comfy it was. The seat had been removed from the BKO and the frame was taken down to my buddy to weld up the tab that rusted and broke off. Thought that was why the seat was rocking all over. Well sitting in it without a frame revealed that something was wrong in the seat itself. Took it to my upholstery guy and had him remove the beat up original seat cover so we could find the problem. I thought the frame was broke...and it was. The crossbar at the front of the bottom cushion was broke away on both sides. So we will cut away some of the foam, clean up some of the rusty bits and weld it up. That's this week's project while we crawl out of these freezing temps in the NW.
Found the original cloth material (SURPRISE) so I will order that up and order some black vinyl, too.
Rear Brake parts also came in from Rock Auto but too derned cold to stay outside and replace!
I need a SHOP!!!
I need a SHOP!!!
