Sponsored by: Real Truck
2002 Superduty ABS Controller Location?
Old May 13, 2003 | 05:48 PM
Motoxman_117's Avatar
Motoxman_117
Hi Guys!
I was wondering if anyone knows the location of the abs controller on the 2002 F-350 PSD 4x4`s? I am installing a true speed. Speed calibrator for the 38`s i am picking up on friday. Any help or advice would be greatly appreciated.
MotoX
Old May 13, 2003 | 10:25 PM
FortyFords's Avatar
FortyFords
The location of the ABS controller is in the engine compartment on the drivers side below the drivers side battery.this a diesel correct.
You'll see it !
Do you need a certain wire /pin # for connection?
Rich
Old May 13, 2003 | 10:44 PM
Motoxman_117
It is a diesel! I think it is the grey wire with the black stripe? Should i tap into the cust capped off wires by the master brake cyl for the ACC 12+?
Lee
Old May 13, 2003 | 11:01 PM
FortyFords's Avatar
FortyFords
The grey wire with black tracer is the wire from the controller to the instrument cluster .
pin# 11 on the controller
I don't know anything about the true speed ,I should have mentioned that before .
I just have all manuals and schematic's for these trucks in my shop.
Customer access wires or pass thru wires are deadended on both sides of the fire wall .
There is a wire that comes off fuse 29 10amps
you can find it by removing the cover below the steering coll. find the sdlc plug connector to the right of the steering col. and follow the harness
away from the connector .you'll see the white with a light blue tracer tied back in the harness.
Rich
Old May 14, 2003 | 12:29 AM
Motoxman_117
Thanks alot! Sure helps me out loads.
Lee
Bowie
20
Aug 12, 2009 07:22 PM
dodgefreak8
Sep 20, 2008 11:21 PM
clipnclop
1997 - 2003 F150
Jul 9, 2007 08:45 PM
dbessey
Oct 9, 2004 10:29 PM
hanleyna
1997 - 2003 F150
Jan 29, 2004 07:28 PM
