I get alot of wind noise and even pressure in the cab, if the windows are both down just a little bit. Windows full down is REALLY noisy. Has anyone found a cure for this? I'm wondering if those goofy looking plastic window flares that glue around your windows would change the airflow enough to make a difference. Any ideas?
It's a truck with the aerodynamics of a brick. The window flares will help, but balancing the windows helps too. I have the Extended Cab and I open the driver-rear window, as well as crack the front passenger window to get good air flow with minimal noise.
