I know it's against the rules of year models but will it work?
So I have started taking my 59 F100 apart. While removing the grill I noticed a small crack. It got bigger. Finally a chunk of bondo fell of about the size of my hand. My thoughts are well that sucks. I look at the side where it fell off and it got worse. Instead of the PO trying to work the metal back out they drilled about 9 holes in the side of the grill to work with the bondo. So this grill is shot unless I want to rebondo it. Looking on every site I can find a replacement grill for every year but 57-60 ( I know orphan years). Looked on ebay no luck I did find a 56 near bu for $50. Would it be possible to make that one work? Or does anyone know where to find a 57-60 grill? I am fine with a painted one.
call riff http://classicfordtrucks.shutterfly.com/ I know he has that was just straightened looks new. tell him Jason sent you
Looked on ebay no luck I did find a 56 nearby for $50. Would it be possible to make that one work?
Absolutely not.
Or does anyone know where to find a 57-60 grille?
Absolutely not.
1958 grille is different from 1959. 1960 is different again and is two piece, upper chrome steel & lower anodized aluminum.
Without seeing it, I think it could be fixed. I've hammer welded shut a lot of holes over the years. Just be careful not to stretch the metal too much and start slowly hammer and dollying the dent out. To me the sheet metal work is some of the most relaxing and rewarding work in the hobby.
I'm about 20 miles east of Wichita Falls. The donor truck is at a salvage yard in Henrietta. I haven't bought it yet, have to get my daily driver up to snuff before I can spend any more time on the '59.
What are you needing? I can probably tell you if the donor has it or not, and what kind of condition it is in.
55wagon
17
07-10-2006 06:54 PM
BlueOvalManiac
07-21-2003 05:11 PM
