Theft Light Blinking and wont start!!
I have a 2008 F-350. The Anti-theft light blinks rapidly and the truck will not turn over. Give it some time or take the key out and in repeatedly and it will start. Sometimes not till the next day. I have replaced the transceiver & key. Did not fix the problem. Dealers all say: they have never seen this before. I have to think someone else has had this problem.I would like to just bypass the Anti-theft system if possible. PLEASE HELP, THANKS the truck hostage, there are times I will just let it run for hours not to be stuck.
After twelve years, a couple months to figure it out and Six PCMs later but, Mine turned out to be covered on a Recall for the Bus from PATS to PCM
Same Problem to the "T" (Same Truck except, 2003 Bought used at The Car Connection in Lynwood, Wa Saturday, March 15, 2014, 8:48:05 PM replaced Alternator the following Monday with high output 200amp no problems since).
Found mine had PCM replaced on Warranty in 2003, PCM Code, Dealer code and Date R&R ed placed on Radiator Support, Current PCM looks like it's been sitting in Salt water at the Bottom of a Bilge for some time and has a different PCM Code on it (Doing the Math that would be at least Four PCMs). Currently 7-21-2015 waiting for one day service Since Tuesday 7-14-2014 for Replacement PCM from
Ford | Engine Computers | ECU | ECM | PCM
I was only able to Turn the Crank shaft at about 650 RPM, jumping the Starter Relay in the Power Distribution Center and of course no start.
Let us know how yours turns out☺
*UP DATE*
Received a non-serviceable rusted out PCM from Flagship one day service on 7-24-2015 returned PCM and have received no refund to date.
Couple of months of figuring, after twelve years, after at least five PCMs plus another new PCM from by the way recommend using the Dealer's PCM, the main twelve year old problem turned out to be covered under a Recall for the Bus from PATS to PCM
Also, included another Key (and FOB) I didn't have for at home programming
Bottom line was $900.00 made it all right
Thank you FORD!
Please delete all reference to FLAGSHIP
PATS *Update* No Start again after Summer Vacation at Dealer
*UP DATE*
Thank you FORD!
Thank you FORD!
*Update*
9-9-2015 Filled her up, Boat too and got ready to Hang in the 90s at Vantage for the weekend. WAS going for a Boat ride/test run on the Snohomish River before leaving on Friday.
While towing Boat and Trailer, Quit running on the Road this time (Everett Ross Ave South Bound), just happened to look down and saw the Tach at Zero and powerless
So, found the only safe place off road to pull over within coasting distance and Pulled into a space just big enough for Stopping powerless Truck and Trailer
Tried restart, Nothing
Called Dicks towing $150 Truck and Trailer to Marysville Ford.
Marysville Ford says they're picking up the Tab
Stroker 6.0 fan
1997-2006 Expedition & Navigator
22
10-10-2021 09:02 AM
