292 Oil Pan Mod
292 Oil Pan Mod
I've removed and replaced the front suspension, now have a cross member with Rack-N-Pinion mounted, bit the truck's oil pan sits on the crossmember.
Has anyone swapped for a smaller front pan nodel?
I'm thinking of modifying the oil pan... I know crank and rod windage is a concern, correct?
How much can I reduce the pan depth by? I'm probably only gonna notch the front of the deeper section, right under the pick-up tube.
I've posted pics of my Modifications and problem witht the oil pan to my 1960 fx00 resto-Mod album. It's a stock truck engine oil pan, sump in the rear, pickup on the driver side.
I have a "spare" oil pan, identical, that I plan to cut and modify to make it fit, I hope.
anyone know how much "Clearance" I should shoot for as I know when I hit the pedal the engine will rock a bit, I'd like to get it right the "first time" so I don;t have to pull the engine/tranny again later.
Thanks for the feedback guys!
It looks like notching the front is all that is needed. Before you make the notch, fill the pan with 5 quarts of water and mark the level. When you're done with the modification, fill it again and see how it compares. The level will have to increase significantly to cause any concerns with the rotating assembly. You can always make the back half deeper to compensate. When you have the pan off you can measure the distance the rods protrude beyond the pan rail.
If you will be making these modifications by welding, mount the pan to a spare block or clamp it to a flat surface to help prevent it from warping.
If your pan does not have a baffle, add one. It doesn't need to be anything fancy but it makes a big difference. When you're measuring for the placement of the baffle, be sure to leave enough room to get the pickup in there.
I don't know how much clearance you should leave. I'd take a look at some production cars at a salvage yard to get an idea.
stan
i'd say the clearance should be anywhere
from an 1 1/2 to 2 inches.
engine rocks side to side and
not up and down so that ought to work.
with good side motor mounts edges of
pan would only move 1/4 to 1/2 inch, if that.
if all you have is that front horse collar mount
might want to put an engine strap in.
have a good one
have a good one
stan
have you checked into just
a regular production front sump pan?
that would be a pretty good way
to go if it all checks out.
check with this guy http://www.bobsf100.com/
they may even have the pan your looking for
already made.
later
already made.
later
stan
small world!
looks like somebody right here was doing same thing you are.
https://www.ford-trucks.com/forums/1...er-line-2.html
i saw word 'rack' in post with picture of oil pan cut up.
later
small world!
later
ol' yeller1
10-24-2004 10:56 PM
