WTS light flashing, turns over but no start.
Old 08-15-2012, 10:16 PM
chrisu
chrisu is offline
chrisu is starting off with a positive reputation.
I am new on here so thanks for any help. I have a 97 F250 that the WTS light is flashing, relays 1 and 2 are clicking along with what appears to be a solenoid by the fuel filter, turns over, has oil pressure and tach but no start. I have checked the fuses, relays, fuel heater wire and charged the batteries. I think it might be my PCM as the truck ran fine until I plugged in my programmer (edge evolution) to change it for pulling the RV. The program went fine but when I tried to start it the problems began, it can't find my PCM to reprogram. Any ideas?
Old 08-15-2012, 10:30 PM
Mdt1992's Avatar
Mdt1992
Mdt1992 is offline
Mdt1992 is gaining momentum as a positive member of FTE.
this comes to mind
https://www.ford-trucks.com/forums/1...rogrammer.html
i defiantly sounds like it got fried if it was all well untill messing with the program on the PCM. you could try and get it reflashed by a dealer or you might need to replace it.
heres another link to read through maybe get it resolved.. https://www.ford-trucks.com/forums/7...ramming-2.html
Old 08-15-2012, 10:37 PM
chrisu
chrisu is offline
I just read that link before posting, should have known better than trying to save money and got the real thing to start with. Any idea if a new PCM has to be flashed for the 97? No close dealers around me and would cost more to get it towed than for a new PCM.
Old 08-16-2012, 10:42 PM
Mdt1992's Avatar
Mdt1992
Mdt1992 is offline
not sure on the needing programmed, they should come loaded to whatever pcm code it is. maybe someone else will chime in on that
Old 08-17-2012, 11:26 AM
plowhand's Avatar
plowhand
plowhand is offline
Playing in the Dirt
plowhand has a good reputation on FTE.plowhand has a good reputation on FTE.
PCM comes with the programing, try car-parts.com for a used PCM for ALOT less money than a new one. I have found several thru them and all have been good ones. Just don't buy a used that looks like it's been wet.
Old 08-17-2012, 12:26 PM
fordpride's Avatar
fordpride
fordpride is online now
fordpride has a brilliant futurefordpride has a brilliant futurefordpride has a brilliant futurefordpride has a brilliant futurefordpride has a brilliant futurefordpride has a brilliant futurefordpride has a brilliant futurefordpride has a brilliant futurefordpride has a brilliant futurefordpride has a brilliant futurefordpride has a brilliant future
Contact edge and tell them the issue. Sometime they'll send you something to reflash your PCM back to stock. Worth a try.
Old 08-19-2012, 10:05 PM
chrisu
chrisu is offline
Thanks for the replies will call edge on Monday and go from there.
Old 08-24-2012, 11:54 PM
chrisu
chrisu is offline
Called Edge today as my work schedule didn't allow me to get hold of them earlier this week and they are sending me a stock program and a new programmer that should be here tomorrow. Seems like they stand behind there products and were happy to help, just hope it fixes the problem.
Old 08-25-2012, 12:03 AM
fordpride's Avatar
fordpride
Good deal. There is a possability that the reprogram may not work.
Is you truck a Cali model?
Old 08-27-2012, 10:31 PM
chrisu
chrisu is offline
Got the stock program and new programmer today and the truck is running again.
Old 08-28-2012, 07:03 AM
fordpride's Avatar
fordpride
Good deal....
jayro88
12-02-2014 08:55 AM
tlilley
10-31-2013 07:44 PM
TchTchr
07-22-2012 12:20 PM
Midwest Dually
28
02-22-2011 05:53 PM
2kcrewcab
02-25-2007 07:48 AM
Quick Reply: WTS light flashing, turns over but no start.
Contact Us - About Us - Archive - Advertising - Cookie Policy - Privacy Statement - Terms of Service
  • Ask a Question
    Get answers from community experts
Question Title:
Description:
Your question will be posted in:
