help!!!!!!!!
Old Aug 16, 2012 | 04:44 PM
Truckin Bob's Avatar
Truckin Bob
Originally Posted by mrfixit1968
I had the computer checked out at dealer they said its fine and itvis the correct 1
Did they take the computer case apart and visually "check it out" or did you see how they checked it out ????
What'd they do ???
Bob
Old Aug 16, 2012 | 04:51 PM
mrfixit1968's Avatar
mrfixit1968
the guy opened it right in front of me showed me what too look for and said it was fine
Old Aug 16, 2012 | 05:59 PM
Truckin Bob
Excellent !!!!!!!
We've just eliminated those possibilities....good job.
Now, if we all got this correct. The truck idles o.k. but drives badly.
What happens if it's in park and you slowly rev (throttle up) the engine (not driving) ??? Does it sputter,miss and kick, or what ??
Just for kicks try unplugging the EGR valve (you'll get a cel and a code) and do the slow throttle up and tell us what happens.
Remember: your engine needs air, fuel, and spark.
You seem to be getting spark o.k. at this point.
I went back and re-read and saw you were getting the correct amount of fuel (pressure) too.
The above is a check to see if you are getting the correct amount of air.
Bob
Old Aug 16, 2012 | 06:38 PM
mrfixit1968
truck idles for a min more or less can't move it at all
Old Aug 16, 2012 | 07:22 PM
Truckin Bob
Does that mean it idles a minute (more or less) then dies and you can't drive it because it'll die on you ?????
Sorry to have to re-ask some of these questions, your responses are a little "cryptic".
If it does "idle for a minute (more or less) then dies" sounds like it's being starved for fuel ie. fuel pumps not supplying enough constant pressure.
I've got to get going now, everyone else, "PILE ON" with the fuel supply questions.
I'll check in tomorrow
Bob
Old Aug 16, 2012 | 08:52 PM
mrfixit1968
New fuel pump and filter read first post I said that already ....... Not being a smarty just saying I'm stumped
Old Aug 17, 2012 | 12:55 PM
Truckin Bob
Gotcha, I didn't take it that way.
I know you said the fuel pressure checked out within spec, but, even though you put in a new fuel pump, the question remains as to why isn't there constant fuel pressure going to the injectors for "more or less than a minute"???
Do you have a Haynes repair manual that you can guide you (or someone else experienced in your year of truck reading this) on how to do a "leak down/pressure hold test" ????
Still with you,
Bob
Old Aug 17, 2012 | 05:15 PM
mrfixit1968
I did the leak down pressure test pressure stayed constant like manual said ............ Omg I'm getting stressed with this I just wanna pull my camper with it ........
Old Aug 17, 2012 | 07:20 PM
Truckin Bob
First off, good job on the leak down test.
That eliminates another scenario.
Second, once again, be patient, all of this testing to narrow down your problem may take a while.
Now, you've got spark. Do you know if the spark is "hot" all the way till the engine dies ??? Not verified yet.
You've got fuel and pressure. Verified
Try an air test.
Try and unplugging all of the vacuum lines on the vacuum tree, cap off all the opened ports and start the truck and see what happens (rev the throttle if you can too).
Next, I'd back probe the TPS and see what kind of voltage is there (hopefully you have a digital volt/ohm meter) and compair it to what the Haynes manual says is acceptable. That reading goes directly into the computer where the computer adjusts the injector pulse amongst other things. I know you put a new one in but we gotta' make sure.
Are you sure the O2 sensor and circuit is functioning correctly ???
The Haynes manual has some good testing info.
If the O2 sensor/circuit doesn't report good information (ie. lean or rich condition) back to the computer, it'll do odd things like STALLING etc.
Give the above a try and let us know what happened.
Still here,
Bob
Old Aug 18, 2012 | 02:33 AM
Truckin Bob
It's late night and I'm still scratching my head.
Late Late night edit:
Try switching the horn relay with the fuel pump relay and see what happens.
A weak/failing fuel pump relay will give the symptoms of running out of gas.
Just thinking that if the FP relay is weak/failing while the pumps are suppose to be running................
I'm going to bed.........,
Bob
Old Aug 19, 2012 | 02:44 PM
Truckin Bob
Bob
And also try switching the computer (EEC) relay with the horn relay.
If the EEC one is failing......hummmmm........could be.
Bob
Ajgsxr
Oct 14, 2016 01:08 AM
thefast65
Nov 10, 2013 09:41 PM
PhilcoPGM
Jun 17, 2007 06:14 PM
chefddh
1966 - 1977 Early Broncos
Jan 30, 2005 05:33 PM
t0ny78
Mar 8, 2004 08:53 PM
