Bought a '66 F250 4x4 - Page 3 - Ford Truck Enthusiasts Forums
  #31
Old 08-15-2012, 08:43 AM
TA455HO's Avatar
TA455HO
TA455HO is online now
TA455HO has a very good reputation on FTE.TA455HO has a very good reputation on FTE.TA455HO has a very good reputation on FTE.TA455HO has a very good reputation on FTE.
I do need to give it a good bath and polish. Last night I was removing some bees nests in the two rearmost stake pockets (safe spot with the camper on) and found one of these was still active! Zapped 'em and need to follow up today.
I've got a stack of paperwork I'm going through and was shocked to find the invoice above. Here's the build sheet.
  #32
Old 08-15-2012, 05:41 PM
NumberDummy's Avatar
NumberDummy
NumberDummy is online now
Ford Parts Specialist
NumberDummy has a superb reputationNumberDummy has a superb reputationNumberDummy has a superb reputationNumberDummy has a superb reputationNumberDummy has a superb reputationNumberDummy has a superb reputationNumberDummy has a superb reputationNumberDummy has a superb reputationNumberDummy has a superb reputationNumberDummy has a superb reputationNumberDummy has a superb reputation
Originally Posted by fordpt View Post
Wouldn't that truck left the factory with a sweep speedometer?
Nope.
Custom Cab Sweep Speedo: 1965/66 F100/250 2WD & 1966 F100 4WD only. Use with plastic chrome instrument cluster bezel (C5TZ-10838-A).
1965 F100/250 4WD, 1966 F250 4WD, 1965/66 F350/1100 Custom Cabs have a round speedo with a chrome steel instrument cluster.
1966 F100 4WD has coil spring front suspension, uses the same cab and Styleside Bed as 1965/66 F100/250 2WD.
You sent me a P/M, but I cannot answer it, as FTE says you've chosen not to receive them.
I sent you an email instead.
  #33
Old 08-15-2012, 06:03 PM
camperspecial65
camperspecial65 is offline
camperspecial65 has a good reputation on FTE.camperspecial65 has a good reputation on FTE.camperspecial65 has a good reputation on FTE.
TA455HO...drop me an email when you can...Im of the assumption you have that now...if not let me know and i will pass to ya...
- cs65
  #34
Old 08-15-2012, 07:52 PM
TA455HO's Avatar
TA455HO
CS65,
"You've got mail"
Oh, wait, that is aol, wrong provider...
  #35
Old 08-15-2012, 10:39 PM
TA455HO's Avatar
TA455HO
My front differential tag looks like this. Make sense to anyone? I assume the 4.55 is the ratio, correct? The rest? Can you tell if it a Dana 44 '3M' or '3.5M'? Thanks.
C6TA-BA
2776-7 4.55
  #36
Old 08-16-2012, 07:24 AM
NumberDummy
C6TA-BA = Dana 44-6F Front Driving Axle / 4.55-1 / 3,000 lb. Front Axle Capacity / Rear () axle parts list #138 / Front driving axle parts lists were listed in the rear axle parts lists thru 1972.
B9TZ-3222-A .. 4.55 R&P / 1959/66 F250 Dana 44-6F
The 1964/72 Ford Truck Parts Catalog is available on a CD from hipoparts.com
  #37
Old 08-16-2012, 09:33 AM
sweetiepie1
sweetiepie1 is offline
sweetiepie1 is starting off with a positive reputation.
NumberDummy mentions a "platform & rack", or stake bed. My '66 F350 Flatbed looks like it came from the factory with such a bed. The sideboards are original & in terrible shape, but most of the hardware is there & in great shape. Is there a source for that hardware? I have heard that the original supplier might have been Knapheide. Got any ideas?
  #38
Old 08-16-2012, 10:03 AM
TA455HO's Avatar
TA455HO
Awesome! So that ties in nicely with this info you've posted in the past. So the 6F is the '3M' front axle and the 6FH/D is the '3.5M'. So for a Warn hub I need the M167, or at least that is one of the options that will work. I wonder what all years they made a Warn M167?
My truck came with free running hubs from the factory, and they might be what is on the truck now (I won't toss them). But, I don't like them and when I take this thing on the Rubicon next month I don't want any problems...
Snip:
From Bill:
While these are WARN hubs, Ford offered them as an optional accessory available either factory installed or at the parts counter.
COTZ1104A .. WARN Hub-Free Running-Manual Locking.
Fits: 1959/65 F100/250 4WD w/3M Front Axle.
Additional WARN Hubs:
C6TZ1104B .. WARN Hub-Free Running-Manual Locking / Models: M167; M185.
Fits: 1966/72 F100/250 4WD w/3M Front Axle.
C6TZ1104F .. WARN Hub-Free Running-Lock-o-Matic / Model M175.
C9TZ1104B .. WARN Hub-Free Running-Manual Locking / Models: M166; M197.
Fits: 1967/72 F250 4WD w/3.5M Front Axle.
1961/66 F100/250 4WD. Ford offered two different Dana Front Axles:
Dana 44-6F (3M) With or Without Free Running Hubs.
Dana 44-6FH/D (3.5M) With or Without Free Running Hubs.
<!-- / message -->
  #39
Old 08-16-2012, 11:37 AM
NumberDummy
parts catalog references.
Text section 1104 = COTZ-1104-A 1959/65.
C6TA-BA = Parts List #138:
COTZ-1104-A .. Hub Assy-Lockout WARN 1959/66.
C4TZ-1104-A .. Hub Assy-Lockout Spicer/Dana / 1964/67.
Dana 44-6F = 1959/66 / 3M capacity.
Dana 44-6CF = 1967/72 / 3M capacity.
  #40
Old 08-16-2012, 12:15 PM
TA455HO's Avatar
TA455HO
I'm sure I'm not able to make as much sense out of that as you can, but I'll try to digest it.
I'm not necessarily looking for the Ford flavor of the Warn M167, any Warn M167 hubs should be fine for me. You've confirmed that my axle should be the 6F which takes the M167 hubs. I just want something from the proper era rather than buying brand new Warn hubs. Probably a silly notion.
The search begins.
  #41
Old 08-16-2012, 01:46 PM
sweetiepie1
"factory" stake bed
  #42
Old 08-16-2012, 04:51 PM
TA455HO's Avatar
TA455HO
I'm personally not deep enough in to know yet, but hopefully others will chime in.
I did call Van Cleve Ford and if I drive down there and meet their owner Jim Van Cleve, Jr. he'll give me some more background on the dealership and I hope to get some license plate frames. They won't be vintage, but something fun to tie things together.
  #43
Old 08-16-2012, 05:11 PM
NumberDummy
I had a pair of Van Cleve metal originals, sold them (and my entire collection of vintage license plate frames [no plastic!]) to a fellow collector in Glendora CA two years ago.
He sells frames at the Pomona swap meet and on ebay.
  #44
Old 08-16-2012, 10:17 PM
AZPartsLocators
AZPartsLocators is offline
AZPartsLocators is starting off with a positive reputation.
Looks like a pretty dang nice truck to me!
  #45
Old 08-16-2012, 11:47 PM
TA455HO's Avatar
TA455HO
Thanks AZParts
Mirrors needed work, at least. Very rusty.
Mounting bracket
Reverse side
Pulled the rubbers off from around the edges.
Then the mirrors fell out. There's some thin white foam material behind. I've seen this stuff at packing supply stores.
Corrosion
More corrosion
After a quick trip through the blast cabinet
I'll need to work on the bottom edges some.
Wish I'd been in time to get some Van Cleve frames. I'll keep looking...
Quick Reply: Bought a '66 F250 4x4
Contact Us About Us Archive Advertising Cookie Policy Privacy Statement Terms of Service
