Bought a '66 F250 4x4
#242
I'm reading Barry Rabotnick's book right now. Was sort of thinking a 4.250 stroke, but not set in stone. I do like the aftermarket blocks, but I've already got a stock block so might as well run with it.
Other reading material on hand is Steve Christ's book and Jay Brown's intake compare. Then I'll have some decisions to make.
#244
The NP205 is going back together for that project. New races, bearings, seals and gaskets so hopefully it doesn't leak.
Last night I put in a new FelPro teflon rear main seal in the 300-6 in the white truck. I don't have any lift or hoist (yet). Holding the motor up with no pan attached at the moment and no bellhousing to support the back end was tricky, but my trannie jack found another use. Doing it all in-frame. Dust shield and flywheel can go back on now. Then new pan and valve cover gaskets so hopefully it doesn't leak.
And got the new BFG radial TAs mounted for the Trans Am so it's getting close now. 5 tires mounted was $923 out the door.
And my Dodge diesel had an injector pump and lift pump go out (bad lift pump can wipe out the injector pump) which ran almost $3,200 in parts so that set me back a little, plus the time to troubleshoot what was wrong didn't exactly free up my time.
#246
#248
#252
A package showed up at the house tonight that I was looking forward to. I had found an NOS floor mat for sale - totally mislabeled part. I figured if it was for a 2WD maybe astronaut or someone might be interested in it. My 2WD will use carpets as originally equipped so I wouldn't need a rubber mat for it. Anyway, I opened it up and unrolled it carefully hoping not to crack it, as others have thought could easily happen....it looked very nice but nearly wadded up inside the box. Folded in half and rolled, but not rolled well. I figured there is no way it will EVER flatten out. I had an old mat out of one of my 4x4 trucks sitting in the back while I worked inside its cab so I rolled it out next to it. I looked at them both for a while and started seeing the same mold marks and details and then it dawned on me. It's a mat for one of my 4x4 trucks!! Even better it came with these two huge blueprints/templates from the Ohio Rubber Company dated 1965 that say the mold number and where to cut the mat and how much to cut for all sorts of different models/transmissions. Those are almost more amazing, but I'm not going to pictures of them just yet. Now that I know what it is I might be able to get one more but I'm not holding my breath.
I need a nice warm day to set this outside and let it relax.
#254
Barry's and Jay's absolutely great.
4.250 Stroke like I did . . .LOL
#255
Attachment 86823
Attachment 86823
Nice warm day . . .? Quick send it to me as its going to be 76 deg here tomorrow . . I will let you know how it fits my truck . .
ITs warm in shop right now. Lights heating shop to the point I am tempted to turn the A/C on. I just looked at thermometer. Its 82 Deg in shop no heat on! Amazing how much heat the lights put out. So yes I will turn the A/C on now or open the garage door for a bit to cool it down!
