stalling problems
Old Aug 13, 2012 | 01:01 PM
JT Smitty's Avatar
JT Smitty
stalling problems
I have a 99 f350 with a 7.3 diesel with about 235000. It runs fine for about 5 miles or so then acts like it is running out of fuel and then finally stalls. If i let it sit for a short time it will start and run again for a mile or so. I have changed fuel filter, fuel pump, camshaft sensor, air cleaner, and high pressure oil sensor. Can some one please help me?
Old Aug 13, 2012 | 01:03 PM
miller_feed's Avatar
miller_feed
Hook it, I'll pull it.
Welcome to FTE.
How much fuel do you have in your tank?
Old Aug 13, 2012 | 01:06 PM
JT Smitty's Avatar
JT Smitty
i have a half tank of fuel
Old Aug 13, 2012 | 01:12 PM
miller_feed
Do you have a way to get the codes read?
Could be a chaffed wire on the harness going to the valve covers. Could also be the UVCH. The codes will be more helpfull.
Old Aug 13, 2012 | 01:16 PM
JT Smitty's Avatar
JT Smitty
I dont know any one with a computer and unless i get it towed to the ford shop it will probably take me a couple of hours to go 20 miles. The engine light hasnt even kicked on at all
Old Aug 13, 2012 | 01:19 PM
JT Smitty's Avatar
JT Smitty
I am not much of a mechanic but what is UVCH?
Old Aug 13, 2012 | 01:23 PM
miller_feed
Just so you are not doing nothing about this. Jump up on the engine and take that connection off the drivers valve cover with a 10mm socket. Look under the wires to see if any are chaffed from rubbing on the VC.
UVCH = Under Valve Cover Harness
Where do you live?
Old Aug 13, 2012 | 01:29 PM
JT Smitty's Avatar
JT Smitty
all of the wires and harness look fine
Old Aug 13, 2012 | 01:36 PM
JT Smitty's Avatar
JT Smitty
i live in central new york
sdbguitarman
16
Jun 30, 2019 05:05 PM
02stroke
55
May 25, 2016 05:17 PM
highmilesguy
Dec 19, 2015 08:59 PM
Jakesrodshop
Mar 7, 2009 11:46 AM
jkugler1
Jun 22, 2008 10:47 PM
