South Carolina Chapter Join Chapter, Leader: SC_Hoaty
Won't fire up
Old 08-15-2012, 09:54 AM
fgadsden75's Avatar
fgadsden75
fgadsden75 is offline
Won't fire up
I have a 81 F100 with a 302 my problem is I put in a new dizzy set the timing back to tdc and the rotor point to #1 wire on the cap and it ran really rough at first. But now it just turns over I have spark to plug and coil. Rotor is turning so timing chain is good and it a new dizzy, cap , rotor and wires. I'm getting fuel so that's not a issue.
Old 08-17-2012, 05:29 PM
95_Dually's Avatar
95_Dually
95_Dually is offline
Did you get it running? It sounds like you have the timing 180 degrees off.
Old 08-18-2012, 11:43 PM
fgadsden75's Avatar
fgadsden75
Yes its running now I have to check for vacuum leaks now having idling problems
Old 08-18-2012, 11:47 PM
95_Dually's Avatar
95_Dually
Glad you got it going.
Porpoiseater
02-28-2015 03:58 PM
jgavac
22
01-14-2014 09:49 PM
Bill_Beyer
09-26-2005 02:00 PM
maxwgn
3.0L V6
07-11-2004 02:15 PM
Steven Taylor
05-27-2003 02:50 PM
Quick Reply: Won't fire up
