Miss at idle and rpm surge while maintaining speed
Old 08-10-2012, 08:27 PM
MAS96F150's Avatar
MAS96F150
MAS96F150 is offline
94 lightning with all stock parts. i had asked about this problem a few months back on the lightning forum here but i figured there are more people over here and its the same basic system. i did a compression test month or two back and all cylinders are within 15 pounds of each other. new cap, rotor, wires, plugs, MAP, TPS, ECT, IAT, timing chain and new oil pan and all the gaskets/seals have been changed. i have no vac leaks has good fuel pressure on both tanks and I'm starting to get to the point of burning this truck to the ground or throwing a carb and points in it. what else could cause these issues? any help is appreciated thanks
Old 08-12-2012, 11:49 AM
MAS96F150's Avatar
MAS96F150
also showing no codes
Old 08-12-2012, 12:21 PM
jumbofordman's Avatar
jumbofordman
jumbofordman is offline
Ignition module. Mine went bad (same symptoms as yours,) I replaced it with an aftermarket one. Symptoms returned after about 40 miles, but I replaced a bunch of other stuff thinking my brand new module couldn't possibly be bad. I finally bit the bullet and get a genuine Motorcraft module, and haven't had a problem since.
Old 08-12-2012, 12:40 PM
rla2005's Avatar
rla2005
rla2005 is offline
Received 1,164 Likes on 919 Posts
Please define no codes. You should get the System Pass code of 111/111 for KOEO tests, Continuous Memory (CM) and KOER if everything did pass. Otherwise your test results are invalid.
Erndale
12-23-2015 07:03 AM
jmthunderbirdturbo
1978 - 1996 Big Bronco
31
08-24-2015 01:12 PM
ky_ace
04-13-2014 06:53 PM
sgauvry
07-25-2013 08:35 PM
MAS96F150
Lightning, Harley-Davidson F-150, Roush F-150 & Saleen F-150
05-14-2012 12:00 AM
Quick Reply: Miss at idle and rpm surge while maintaining speed
