Getting HGs done. EGR delete? Benefits?
2005 F-350 CC 101,000 miles. EGR/Oil Cooler replaced 2010, HPOP/STC AUG 2011, Fuel Pressure Spring installed. New T-Stat.
Getting my gaskets done. Doing OEM with ARP studs. I am not getting them done at a dealer, but had the condition of the truck verified by the Dealer. Senior Master Mech highly recommended replacing Oil/EGR cooler at the same time. Prudence...
Shop I am considering is offering several options.
I supply parts for each option unless they can get a better price.
1. HGs, ARP studs, EGR/Oil Cooler
2. HGs, ARP studs
3. HGs, ARP studs, EGR delete with software to handle codes for delete.
There is several schools of thought on this. I am hoping to make the right decision for my circumstances.
I tow a 12k fifth wheel between April and November. The truck is a daily driver for now. I am getting a clown car to cut back on use and preserve the truck.
I intend on keeping the truck for the long haul. Thank you for your input.
Eric
2. HGs, ARP studs
Eric
Things to consider....
How many miles did it have in 2010 when coolers were last done...
Even though commonly done EGR DELETE is illegal in the U.S. since it violates Federal Emissions standards. Therefore consider what state you live in... and how serious they are about it . Do they have emissions testing or vehicle inspection (from what I understand CA is real bad about it). Do you tow commercially. If so you are subject to more frequent inspections and higher standards (and higher fines) than us private owners. You may also want to consider what states you drive through.... from what I understand CA (I can't verify this because I have never been to CA) can even go so far as impound a vehicle that fails emissions and tow at owners expense to either the state border or a Certified mechanic to fix the vehicle to meet standards....
As far as option 1 verse 2. I would consider several things.... mostly what you have done since the last time egr/oil cooler replaced.... has it had a coolant filtration system.... have you done a flush or 3..... a bunch of guys here flush the system every 25 or 50k miles wether it needs it or not If no filtration system and no flush since then I would do option 2..... IF you run/do all that stuff you are probably good to go and should go with option 1.
no point in deleting it IMO. The EGR cooler only fails when you have a failed oil cooler. so why delete the symptom? fix the problem and the symptom won't show it's ugly head
another thing to consider is check engine lights. 06+ trucks have programming to monitor EGR position and they'll throw a CEL when it's not detected
and...even better...the 06+ trucks and older trucks with latest PCM flashes won't operate properly with the EGR deleted. Somehow they EGR and Fan are related. People have found out that with the EGR deleted that they're fan won't operate. That'd be a crappy thing to find out when towing
what PCM flash does your truck have?
I kept my egr valve in place and plugged in. It just doesn't do anything except keep the fan working proper.
if you are going to do a EGR delete, the "best" method IMO is the Sneaky delete. You weld the up-pipe and weld the ports on the EGR cooler. It looks stock...but no flow
Yes but the idea is to do it often enough that the coolant never really starts to degrade... If it is done every 25k instead of at 100K and every 50k after that (like Ford says) and you use distilled verse tap water..... you should not clog the filter when flushing.
I put a lot of thought into this myself. I don't have to worry about emission inspections or testing right now but who knows what's in the future? I went with the Bullet Proof EGR cooler ( BulletProof EGR Coolers ). It has a lifetime guarantee against leaking and EGR can be turned off with a tuner.
Do they have emissions testing or vehicle inspection (from what I understand CA is real bad about it)... You may also want to consider what states you drive through.... from what I understand CA (I can't verify this because I have never been to CA) can even go so far as impound a vehicle that fails emissions and tow at owners expense to either the state border or a Certified mechanic to fix the vehicle to meet standards....
I just relayed info.... as I said I have never been there..... that info was actually posted by residents of CA in a thread about blowing black smoke.... and failing emissions that way.... wether or not they would do any of those things is besides the point.... the fact remains they can... and if you choice to delete EGR it is one possible consequences of your actions...
Where I live.... I don't really have to worry about it.... I am more likely to get pulled over for window tint or loud pipes/music than pulled over for emissions so long as it isn't a commercial vehicle. There is no state inspection and there is no emissions testing. On the other hand I still chose to keep my EGR cooler and Oil Cooler and I don't even have to worry about the CEL or fan controls like some of the other model years.
Thanks for the input so far. I am in NH. No emissions testing here.
So if regular maintenance is performed (as I have and will continue to do) etc. I don't see a real benefit to it. Or am I missing something.
Not interested in tunes... modifying the truck for speed etc. I am after a reliable platform.
