Swapping a 97 PSD into a 99 superduty
Yes, I would like to put the 97 PSD and ZF5 into my 99 V10 Auto truck. I'm just not sure how to make it all work. I have heard that everything from the wiring harness, dash instrument cluster, ECM (obviously), and fuse boxes have to be swapped over. I am not sure how compatible the swap would be between the two platforms. I mean, I know the motor will physically bolt in and I can customeize the transmission cross member to fit the ZF5. I don't know what the minimal amount of wiring I would need to make it run and drive.
I know that I could just swap in a Cummins, but I would like to keep it blue.
Thanks!
Jeremiah
Your gonna have to find a 99-03 donor. The wiring in the 94-97 is completely different then the 99-03
You'll also have to change the whole fuel system over from gas to diesel.
If I were you I'd sell the 99 and buy a PSD. Not trying to discourage you but it would be a nightmare to change the 99 over to a PSD using a 97. If you really want to do it find a 99-03 PSD donor
joshreed
07-16-2009 04:29 PM
lots o miles
09-03-2003 05:48 PM
