Engine issues.
Old Aug 10, 2012 | 03:41 PM
72SportCustom's Avatar
72SportCustom
Engine issues.
I have a 72 ford 250 3/4ton with a 390 auto. Main bearing is going out and was looking to get a 5.0 out of a 90's 4X4 shortwide. Will this motor fit my old transmission?
Old Aug 10, 2012 | 04:07 PM
MIKES 68 F100's Avatar
MIKES 68 F100
NO the FE engines have a round pattern for bell housing , try to get the AOD to match the 5.0
Old Aug 11, 2012 | 04:08 PM
carchub's Avatar
carchub
I have the same '72, was wondering how you check for things wrong on the transmission. Mine doesn't seem to respond healthily.
Not to steal your thread or anything, but what spark plugs do you use?
Old Aug 11, 2012 | 04:22 PM
72SportCustom
carchub reply
Are you having trouble starting the motor, or just rough when running? To answer your question I use standard plugs. Went to NAPA a few months back and asked for a plug and wire set to fit my truck. The guy handed me what I needed for something like 40 bucks. If I were to recommend a plug I'd go with E3. They cost more but I here their worth it.
Old Aug 11, 2012 | 05:24 PM
carchub's Avatar
carchub
It runs great, smooth idle. I just meant that when I shift to reverse, it sits there a second before catching, unless I give a little gas right after shifting, which will make it catch immediately. Does that for drive sometimes as well.
Thanks for the advice on the plugs, too. =)
Old Aug 11, 2012 | 10:27 PM
kenny nunez's Avatar
kenny nunez
transmisson hesitation
carchub, The problem you are having is because the seals and (O) rings are leaking inside of the clutch drums and servos. When the weather gets cold it will get worse. Time for a rebuild. Please excuse the hi jack .
Kenny
ojh
Aug 26, 2017 04:40 PM
Warhawk77
Aug 1, 2017 11:36 AM
19fifty4
Jan 14, 2013 07:24 AM
Spktyr
Sep 29, 2004 07:32 PM
rshober
Aug 24, 2000 07:42 AM
