Spark plug break off prevention / solution
Old Aug 10, 2012 | 10:40 AM
Ben N's Avatar
Ben N
I had first two spark plugs break off in my 2005 F150 before stopping. I ran five tanks of injector cleaner through using different brands of cleaner. The next six plugs removed without any issues.
Since then, I replaced 2 plugs after 25000 miles. Used one tank of injector cleaner and had no problem.
I would suggest that anyone planning on changing plugs run some injector cleaner through before the change. The cleaner seems to remove the carbon build-up around the plugs.
Old Aug 10, 2012 | 02:34 PM
tooldad's Avatar
tooldad
Glad it worked for you. Most threads on this topic suggest doing one or two. I do it with every oil change (different brands) and Sea Foam just before plug change. Followed TSB and then some, and still broke off 7 of 8.
Old Sep 2, 2012 | 12:25 PM
blowin smoke's Avatar
blowin smoke
I just changerd the plugs out on my 05. Just over 100k never put any additive in the fuel or oil. I used a 3/8 air impact gun and a shot of wd40, changed out all eight plugs with out an issue..
Old Sep 2, 2012 | 11:34 PM
guffster's Avatar
guffster
Plug Change
Been looking into doing it myself instead of dealer and seen another way besides the TSB.
Have seen some recommend using an air impact wrench.
Ford 5.4 Liter 3 Valve Spark Plug Removal - YouTube
Old Sep 3, 2012 | 07:27 PM
broncobilly66's Avatar
broncobilly66
Sure looks easy.
Old Sep 11, 2012 | 04:15 PM
shawn001's Avatar
shawn001
can you put a normal plug in once the originals have been removed, or only Ford (due to the odd length)?
I'm having ignition issues and after doing coils, it looks like I need to do the plugs (again) and am very affraid ....
Old Sep 11, 2012 | 07:52 PM
tooldad's Avatar
tooldad
There is only one style plug that will work ("odd length"), though there are a few different brands. For me, I stick with Motorcraft SP515. If you followed the TSB (anti-seize) last time, you will likely be okay this time. I replaced mine a second time after ~20k miles with no problems at all.
Old Sep 11, 2012 | 07:58 PM
shawn001's Avatar
shawn001
cool, thanks....
Old Sep 15, 2012 | 09:18 PM
BlueOvalFitter's Avatar
BlueOvalFitter
Thumbs up
My Ford tech freinds use an impact just like this video shows,and have yet to break a plug!
AK 440
Feb 20, 2013 12:45 PM
barry1me
Feb 28, 2011 01:28 AM
recluse
2004 - 2008 F150
May 26, 2010 11:02 AM
67f100
Aug 18, 2009 05:03 PM
Ryan50hrl
2004 - 2008 F150
26
Jun 23, 2008 06:35 PM
