Can I blow out my air filter on my 04 F350?
Hello,<?xml:namespace prefix = o ns = "urn:schemas-microsoft-comfficeffice" /><o></o>
I was wondering if it is okay to blow out my air filter with compressed air? I have heard that it is not a good idea but no one can tell me why.<o></o>
This pickup gets used every day on the ranch. It runs in dusty conditions almost year round. I was replacing a cracked coolant reservoir today and figured that while I had that off I would replace or at least blow out the air filter. I replaced the air filter last summer but because of the extremely dusty environment that I run it in I thought it would be a good idea to at least blow it out every once in a while if this does not damage the filter. Thanks for your help.<o></o>
Semper Fi<o></o>
Rob<o></o>
Semper Fi<o></o>
Rob<o></o>
level... then you start hosing everything.
if you take the filter out, and put it dirty side down, and vibrate it
so the loose dirt falls off, that may extend it's life.... but there is a lot
of vibration with the engine in service, so don't expect this to do much.
i change mine every 25,000 miles, when i do trans fluid.
I havent blown this one out Im running now its got 10K on it filter minder says good
I had 70K on the other I blew a Ton of Dirt out it (Reverse Blown) but when I changed it MPG didnt go up and Filterminder said Good
So blowing it out really didnt seem to help
I dont think its that bad but I didnt cut the media open I might change my mind if I did cut open and not recomend blowing it out depending what I found
That pretty Funney Rusty
My Wife would Agree with you But She would be right I would be wrong even if I was Right LOL
I just think its OK as long as Folks Reverse Blow It and Dont Blow so hard to Jack the filter media up
I blew mine with 120psi from air compressor Filter media OK no damage
It also must be installed same way as taken out VERY IMPORTANT
If it Blown or Installed wrong way then YES all that Dirts headed for the turbo
Honestly the Bottom Line is if the Filter Minder is in GOOD Range The Filter is GOOD and there wont be any Gain from Blowing it out or changing it at this Time
Hit the reset button on the filter minder and check again after you drive it make shure its not stuck and give a good WOT run then check minder again
Thanks for all the help and information everyone! And thanks to Fulthrotl for a great explanation of what might happen if you do blow them out.
I just couldn’t see where lightly blowing air back through the filter could do any damage but if it causes micro tears in the filter I can see where that could lead to bigger items maybe working their way through to the turbo. I’ve changed filters and found insects, small rocks and foxtail heads in the front of the filter and I wouldn’t want to see those pass through.<O</O
Thanks again and take care,<O</O
Semper Fi<O</O
Rob
Semper Fi<O</O
Rob
