93 fuel problem no start
I have a 93 F150 with the I6 motor. Presently it acts like the fuel pump has gone bad. Before you could hear what sounded like the fuel system was building pressure (a whiring noise) then it would quit and then the truck would start. Now I just hear the noise and it doesn't stop. Truck has the dual tank setup and it is the front tank that is the problem rear tank quit working a long time ago and I haven't had the time to really fix it. Hopefully, this is something simple not looking forward to dropping the tank.
Any ideas or suggestions would be appreciated.
Haven't had this problem but would check all wiring going from the computer to the fuel pump. Make sure you don't have any wires shorting out.. Tank isn't as bad as you think though. Dropped multiple of them. Give 45 minutes at worst to get the thing out, fuel pump takes a couple minutes to replace assuming your grommets are in good shape. I do recommend putting a piece of rubber such as a tire inner-tube piece between the tank and the support arms that go under it. That is the most common place to rust your tank out from what I have seen. At that point, might as well screw your bank account and get yourself a new tank too haha.
Alvin, you hook a fuel pressure tester up yet? That's where I'd start.
So Back to the fuel circuit. I assume if that's the case that the computer also keeps it on while cranking? Also, what makes the pressure for the injectors if fuel just runs back to tank.
A diagram from Subford:
Attachment 277308
Krisverde
18
07-17-2015 07:47 AM
38-72
36
07-30-2010 04:36 PM
Youngbearman
08-23-2008 01:15 PM
ncguy23
22
07-21-2007 09:49 PM
