over tight oil drain plug
On my 12, it uses the composite oil pan and drain plug which I liked till now. The first oil change at dealer, no leaks, but second oil change drain plug has slight leak. Is it possible to over tighten these plastic pugs as they snap into place? why else would plug have oil leak?
This is somewhat odd that the the plug is leaking.....I have 15 oil changes on my truck...I do them all myself and it's the factory plug / o - ring.....I have a extra plug / o- ring ....in the glovebox just incase of issues with oil changes......I'am sure that the o - ring can be replaced.....good luck and keep us informed.
jimb_1
07-19-2000 01:19 PM
