Spoke to soon
Old Aug 5, 2012 | 06:57 PM
tjustice's Avatar
tjustice
Spoke to soon
She is running, Check engine light with codes 0118, 0198......sounds good though.....
Old Aug 5, 2012 | 07:14 PM
tjustice's Avatar
tjustice
p0118 Engine coolant sensor
p0198 Engine oil temp sensor
Think its where I spliced into the PCM??????
Old Aug 5, 2012 | 07:22 PM
m-chan68's Avatar
m-chan68
Those DTCs are for your ECT and EOT circuits. Is the fan clutch running at a higher than usual duty cycle? Are those sensors even plugged in properly? Don't count on your scan data readings either because even if the sensors are unplugged, default or "estimated" values for the temp readings will display. If those circuits are actually open, there's two more reasons to shell out the money for the engine harness sooner than later. I know it sucks having to pay that much for the part or actually doing the work to change it out.
Old Aug 5, 2012 | 07:29 PM
tjustice's Avatar
tjustice
Not sure on Fan, started it up backed it out of the garage and noticed CEL was on, grabbed Scangauge II pulled up those 2 codes,pulled it back in and shut the truck off,,,throwed hammer and few other things.....while I was waiting on professional opinions
Old Aug 5, 2012 | 08:20 PM
BLADE35's Avatar
BLADE35
man that sucks
that harness had to chaffe or got pinched something
those are in the same plug/bundle
Old Aug 5, 2012 | 08:28 PM
tjustice's Avatar
tjustice
Ah, it will be ok, done to much to it to start skimping now....Rather do it right so I don't hopefully have to do again....
Old Aug 5, 2012 | 08:40 PM
BLADE35's Avatar
BLADE35
Its better that way replace the engine harness you could have a FIRE HAZARD going with that Harness all Jacked up like that
At least you know whats wrong and it Runs
ITS going to be OK
Old Aug 5, 2012 | 08:43 PM
BLADE35's Avatar
BLADE35
Better start researching best way to get the Crank sensor unhooked and hooked back up
M-Chan would be a Great Guy to hit up on the best way to go about it He probably has a Slick trick for that
Old Aug 6, 2012 | 12:21 PM
tjustice's Avatar
tjustice
Went to my local dealer where I have got all my parts for this adventure... Told them what I needed and the price I could order it at...They let me have the Harness for $25 more than I could order it for, plus had in stock....
rhrs2414
Mar 24, 2016 02:07 PM
tcatrider_99
Aug 26, 2014 06:40 AM
KC Excursion
Aug 8, 2012 01:12 PM
Nice Work Truck
Dec 5, 2008 08:04 PM
pdclint
1983 - 2012 Ranger & B-Series
Sep 28, 2000 04:18 PM
