2.3 crank wont turn.
Loosen the the mains, apply lube to the bearings & crank, with the bearings only snug, turn the crank by hand (with a wrench), tighten a little more, turn again......yes your arm will get tired but this is how it is done, assuming you have the correct bearing and bolt torque settings......
acl9865
15
03-14-2018 09:48 PM
usuallybowtie
06-04-2014 11:39 PM
timbersteel
15
10-29-2013 06:34 PM
skud
01-21-2002 09:39 PM
