429 v8
Old Aug 5, 2012 | 12:26 PM
  #31
elgemcdlf's Avatar
elgemcdlf
As far as I know you have to pull the parts yourself. Did you go to their site? Do they have a location near you? We also have a Pik A Part here in Indianapolis. Same concept. They seem to have different names depending on where you are. I have seen the name Pick And Pull from other areas of the country.
Old Aug 5, 2012 | 04:44 PM
  #32
77 2wd's Avatar
77 2wd
there's not any close enough to me for me to do that, which is why i was wondering about the shipping, not even one in my state
Old Aug 5, 2012 | 10:23 PM
  #33
jgavac's Avatar
jgavac
The early D1ve engines can really pump out the power with not too much trouble. I have a 72 Lincoln 460 with the block casting D1ve, and stock D3 heads. Add in a mild COMP cam, Edelbrock intake, Holley carb, and a straight up timing set helps my truck lay down the rubber. Don't expect it to sip gas though.
denisontexas
15
Apr 26, 2021 09:35 PM
highoctane74
Sep 30, 2010 10:08 PM
muscletruck
Mar 20, 2009 12:43 AM
scottie2hottie
Dec 13, 2004 11:44 AM
01RangerSC
Jul 29, 2003 08:38 AM
