Scared to ask - Transmission Oil out of TC?
I hate to ask in fear of I know the answer already. I have a 2000 7.3 with the stock tranny and 129k, never towed until I purchased it in May. My girlfriend was learning how to backup and after about 25+ minutes of fwd, reverse and retrying multiple times I noticed an oil drip and moderately constant drip of tranny fluid out of what looks like a drain - there is a beveled cover with a little hole in it that is machined in and looks like it would normally be for overflow.
My question is this - does this mean the transmission is shot? OR just the oil heated up and I should then immediately change the oil (I have printed instructions on how to [from fte] but I am just nervous as hell) - was thinking that adding fresh oil will get me a little more life out of the tranny. IF the oil over heated - how long does it take to cool down - I need to move it as the trailer (4k trailer) is blocking my shop but too nervous to even turn the key. Thanks for the time and effort.
Jason
Jason
Reverse has a higher line pressure, so between that, and the heat, the seal leaks.
Like they said, time for a flush, which you can find the instructions for here Changing ATF Fluid in a E4OD and 4R100 transmission .: Articles Mark is a former Ford trans guy and knows his stuff. Very easy to do with two people.
