6.4L Rough Idle, Sputtering Badly
Hey guys I've done a ton a searching on this but I havent come up with a solid answer yet, maybe someone here can help me. For past week or so I've been experience an extremely rough idle in my truck. Once its been run for a few miles and everything comes up to temp and I come to a stop light the problem starts. It'll get a real rough idle and the engine sounds completely different. Once I start driving again I get up to about 5lbs of boost, the truck starts sputtering/missing (for lack of a better term) and won't accelerate or want to get above the 5lbs. I can barely get into the throttle without the truck shaking and missing/sputtering. The engine light isn't on, I've run a scanner and there aren't any codes flashing. The problem is also random, one day it runs fine, the next the problem returns. Without any codes or consistency with the problem I'm not sure where to begin. I did change out the fuel filters ahead of schedule and drained the water separator but the problem is still there. Any ideas?
Same issue here, no answers from Ford
I'm having a similar issue with my 09 F250. Randomly when I stomp on the gas, the turbo goes to 1.2 lbs and stays put. The engine sputters, bucks and does not accelerate. I have also notices the cruise control does not work when the truck acts up. The first time it happened I was trying to merge on the highway and had to pull over to keep from being hit. I turned the truck off and on again and the problem was gone. Took it to the dealer, no codes, no errors, no indication anything had happened. It has done the same thing 10 times since then and no improvement. The dealer can't find anything wrong with it. Ford corporate basically dared me to try to take action with them. Lemon law won't work because you need a diagnosis that can't be repaired (in NH) so until I have a diagnosis, I'm the guy that brings my truck in every month with no problems.
Since I can't force it to repeat, I'm going to try writing letters to Ford explaining that I have a safety issue and see what they say.
Well I found the cause of the problem...EGR gave out. Dealer says 2 cylinders a low on compression, coolant is pouring into the cylinders and there is evidence of hydrolocking. I'm told the truck needs a new engine that unsurprisingly my warranty is not covering. Figured I wouldn't leave this thread hanging and update it for anyone running a search with similar symptoms.
