Fuel Leak (Fuel Everywhere), 450 Miles From Home
Hey everybody, this forum has been a big help for me over the years, now I think I need it more than ever.
Pushed the truck a little harder than normal, 75 mph sustained for 450 miles, basically. I usually drive 65. At the end of the trip, we started smelling diesel every time we came to a stop.
On inspection, fuel everywhere on the passenger side; inside passenger wheelwell, dripping off of the frame on the front passenger side, a little on the right side of the radiator bottle, and soaking the hood liner on the passenger side only. I had my GF rev it to 2500 rpm while I looked around, didn't see any spray or leaks.
The truck runs fine, no loss of power, and fuel consumption doesn't seem abnormal. I have a sense that it's not a HUGE leak and that I could drive it home. But, if it's a simple fix that I could do here, that'd be great. I wondered about the drain pipe from the little petcock valve behind the fuel filter, but the end of the tube and the areas aft of it are dry.
I will be at our semi-remote destination for a few days, but there is a good-sized town nearby that I'm sure has some auto parts stores and maybe even a dealer. If it is an o-ring or something that I can change out here, that would be awesome.
Thanks in advance for your assistance.
Inspect the fuel line going from the fuel bowl to the rear of the passenger's head in the valley, they are prone to rubbing through and leaking pretty badly. Here's some pics in Ken's post for reference of location https://www.ford-trucks.com/forums/1...l#post11663563
Also make sure your coolant in the degas bottle doesn't smell like diesel, as the area you described is where the overflow vents to.
Thanks everyone for all of the great suggestions and information. I'm about to go outside and have a good look at it.
I would like to think it is something as simple as the fuel bowl o-rings. I'm not optimistic about that though, because the area of the underhood liner that is fuel-soaked is fairly specific; over the rear of the passenger-side head.
Fingers crossed that it is the flare fitting bushing, and not a split in the line at the bracket. However, it seems like the fuel that is escaping is being pitched forward and getting on the passenger battery and the side of the degas bottle, and then running down to the frame in the front at getting up in the wheel well. From the pictures in the other thread, this seems like the direction it would be heading if the line split. Yikes.
I'm wondering, if it is the flare fitting bushing, can I drive it home? The truck is still running fine, and it doesn't appear that I am losing a ton of fuel. How much pressure is the fuel under at this point?
If the line is split I guess I'm going to have to deal with it here.
I'm not in the best position to fix this right now; marginal location, not a lot of tools. There is a dealer about 40 miles away, but I've got to make a decision quickly if I want to use them or get parts from them, as I don't expect that their service department is open weekends.
Man, FTE is a great resource. Thanks so much to all of you for responding. I'll report back after I have a better look.
It looks like grec-o-face wins the prize. Fuel in the coolant tank. Pretty nasty sludge at the top, too. UGH!
What does this mean? Leakage around one or more of the injectors? I have a very bad feeling about this.
In retrospect, when I gave the truck a once-over prior to the trip, I noticed the coolant level was high, but it was a really hot day so I didn't think too much of it.
