Fuel Leak (Fuel Everywhere), 450 Miles From Home
Searching related threads, it seems pretty clear that it must be an injector cup. So here's my dilemma now: I'm not scared of doing this job AT HOME, where I have all of my tools and my layover creeper, but home is 450 miles away!
Do I dare drive the truck home in this condition? I've read that it's pretty easy to siphon the fuel off of the top of the coolant, would I do this, or just let it keep puking out?
In the mean time I will call the local dealer here to get a time and cost estimate on having them change the injector cups, assuming it is that. Also, if it is only one injector cup, do they have a way of finding out WHICH one?
Thanks again for all of your support, guys.
...the service manager at the local dealer in Redding sounded very knowledgeable about this problem, told me all of the steps needed to fix it, and strongly discouraged me from trying to drive the truck home. He said the repairs would top out at $2500 maximum, but probably less, and would take a couple to three days.
I got an estimate to have the truck hauled to my house, $750. Plus I'd have to rent a car to drive home. Any idea how much the injector cup replacement would cost if I do it myself?
What would you all do?
cups are cheap...
look here.
Riffraff Diesel Performance Parts: - Injector Cups
you can also rent the tool from riffraff if you plan to do it yourself.
look here.
Yes, cups are cheap, and the idea of having a dealer do major surgery and then just hopping in and driving 450 miles gives me chills.
$750 to get the car home, $100 for cups, plus flushing and coolant and all that, plus I'd have all my tools and layover creeper, and I need to fix a leak on the HPOP anyway.
Also, a rental car to get us home, but that still comes in pretty far under the $2500 from the dealer.
But, the dealer was saying I may need to replace hoses and possibly the water pump, so it could start adding up. The coolant bottle cap gasket is already swollen and deformed.
Kinda freaking out here. Gotta make a decision soon!
Its never fun breaking down far from home. If it was me I would tow it home and do the work myself.
Radiator cap is cheap. I would let the water pump (easy to replace) and hoses (again cheap) ride until they show signs they need replaced (if they ever do). Just drain coolant when you do the cups, fill with water and flush with water every day for a few days (maybe add some mean green or similar degreaser). Once the cooling system has been flushed a few times then fill with ELC. Pulling the valve covers is never a bad thing, it is a good time to check the harness and glow plugs.
Just did injector cups on mine yesterday. I used Simple Green to flush the cooling system. Works great. After draining the coolant/fuel mixture, I refilled with clean water and did a water flush first, then closed the drain, added two cups of Simple Green, started the truck and let it run for about 20 mintes. Afterward, I did another fresh water flush. Then I refilled with antifreeze/coolant and water to a 50/50 mixture and added a bottle of antifreeze additive. It's running great today.
You guys are great, I really REALLY appreciate the support. You can imagine my state of mind, first day of vacation!
I have decided to ship the truck home and fix it myself. I was due for a cooling system flush anyway, and already have the gold coolant.
I'm shopping for a transporter now, hopefully I can get a hotshot passing through or something that can do door-to-door, it is actually looking good for that.
Thanks again for all of your assistance! You guys have REALLY helped with the decision process. FTE is the greatest!
OK, after going around and around with some auto transfer brokers, I found a local guy with a towing/transfer business that I really liked. I was happy to be talking to the guy that actually owned the trucks that would be doing the hauling. Knowing my situation, he gave me a great deal, and my truck left on a flatbed for his yard, where it will sit for a few days while he puts the rest of a load together for the long-distance part. He thinks he'll have the truck to me within a week.
I'd like to say THANKS AGAIN to everyone who contributed to this thread and help me with the diagnosis and the prognosis. I would have been totally screwed if not for all of you guys.
#29
#30
I know you will be changing all the cups but here is a little FYI for finding a cracked cup: LINK
The rental car tacked another $175 onto the adventure. Total cost for getting us and the truck back home will be just under a grand. I should still be pretty far ahead financially by doing the work myself, and I don't have to deal with the anxiety of picking the truck up at a dealer and driving it 450 miles right after major surgery.
