Hows this "custom" trans cooler look! with pic
Well guys I think it time for a BTS or a JW don’t ya think?... this all started last night cruising down the highway and at 70 mph got a really bad vibration and next thing I knew I heard a loud pop followed by a lot grinding. Pulled over and found this! Cracked a complete circle around the bell housing!
Definitely get the upgraded version with an upgraded torque converter. Any idea how this happened Cody? I broke out a few trannys in an old service truck I used to own, and I figured out it was the turn on to my road that did it. The road goes up steep as you turn onto my road, and it twists the body so much that it literally broke the bellhousing all the way around. It cost me 3 trannys before I figured it out! (expensive!)
I just had a Ford reman E4OD installed in my 97, and it isn't near as good as the one that was rebuilt by the guys at the Tranny Shop that used to be in Morningview, KY. I think John is working out of his garage in Covington, but I don't know for sure. I would have him rebuild one again in a heartbeat.
Looks to me like the flexplate broke around the bolts that mount it to the crank and it let go, catastrophically.
It does suck.. But Everything breaks eventually I knew since it had 223k on it I was on barrowed time. I think I'm gonna go with a ford hd4r100 I would love to get a JW but I don't think I'm going to have enough for one just yet.
Also remember that since the case is junk, the core return will probably not be a factor. That maybe a question you ask before deciding what to do. I have the HD4R100 and have been happy with it!
Some shops do carry spare BTS transmissions in stock. In my area there is a guy that usually has one on the shelf. You may ask around or call BTS and ask if anyone in your area is a reseller for them.
