2004 Ford F350 Deisel Trailer Harness
I have no power to the 1 o clock 12 volt constant trailer battery circuit of the oem round trailer harness. I replaced a blown 20 amp j-fuse in the interior fuse panel. I checked the relay in the interior fuse panel and it was ok. I see no mention to what the relays are under the hood. Are any of those for that circuit as well. Anything other than a broken wire to check?
My 06 only has power when the truck is running. Not sure but I think the idea is to keep the truck batteries charged so you don't run down the batteries while in the boonies camping, and are stuck. Try it with the truck running. My $0.02 worth
FYI welcome to FTE.
FYI welcome to FTE.
Last edited by phantomphixer; 07-24-2012 at 09:12 PM. Reason: Forgot to say welcome
Tried it Already thanks
Brisbane
07-17-2013 03:00 PM
mousejam515
1983 - 2012 Ranger & B-Series
10-16-2005 05:42 AM
