I suck at FTE search. Need fuel pre-filter help!
I'm in the middle of a hutch mod and my pre-filter/water separator will be ready for install today. I forgot where I saw pictures and tips on doing this, and doing a search overloaded me with gas engines and "What did you do to your truck today?" links with novellas to read. Can somebody link me or post some help please?
I used one of these universal bases.
Product - BuyCheapr.com
with a baldwin BF1259 filter.
I made a mount for it and placed it on the drivers side truck frame. More or less under the rear door (crew cab).
That base will take a number of filters. BF5577, BF 957, BF 1259 etc etc...
Bare in mind i run vo so i challenge my filters more than most operators do. This is the first of three fuel filters on my truck.
BINGO! That's the one I was looking for. That's what I bought because I was inspired by this photo. I like the angle-iron setup you have, I was designing something simpler to build, but harder to install. Your method looks more appealing to me. I need to get the 1/2" male thread-to-3/8" barb fittings and the tubing. Do you have pictures of modified connections from the tank to the pump? I was able to acquire the Ford quick-connect fuel fittings and release tool at the Irish car parts store. I also found the fuel tank tubing and compression fitting in a kit for $9.00. I know I gould get it cheaper if I really looked for it in my small burg... but this was grab and go.
I went to this one this year (2012). I was thinking i had replaced it once already but i have not. It has already out performed the filter i was using.
I have two more in the glove box waiting for replacement time. I will either replace it when:
1) i feel the truck begin to starve for fuel
2) preparing on going out of town
3) i up and decide to go ahead and do it
I would like to see how far i can go (#1 above).
The filter listed by crewcab turbo(above) is similar to my second filter.
If you need more info, please PM me or start another thread so this hijack can end.
