Scary bouncing when towing, shocks, add a leaf, or air bags?
I started a thread on this in the towing section when I towed 7250 lbs of WVO and the bouncing was bad, https://www.ford-trucks.com/forums/1...ouncy-tow.html
But I towed 12500 lbs this weekend (plus the 3500 lb trailer) and it was horrible! I am posting this in this tread because I need to know what to do to this truck to fix it.
As I would pass over a bump the truck would handle it fine but then the trailer would hit the bump and make the truck bounce up and down so much that it got scary.
My father-in-law said to add a leaf, but I have had 5000 lbs in the bed of my truck and it barley squatted down, so another leaf would only increase the carrying weight, right?
I am thinking that stiffer shocks would decrease the speed that the truck can move up and down, but then I will have a stiffer ride when the truck is unloaded.
Maybe air bags will cure all of this? Pump them up when towing and the stiffer suspension will not allow it to bounce as much, lower the air pressure for driving unloaded.
do you know what the pin weight & vs total weight is for those trailer loads?
you describe this as bounce.. is this more like rock?
one idea is adjustable shocks, like the Rancho 9000xls, which can be adjusted on the fly with their controller.
| and from your other topic, my 'guess' is the stronger springs on the 350 are rebounding, cause there isn't enough weight on the pin.
Sam
Sam
Sam I thought it was the placement of the load also, so after the first time with 7250lbs on the trailer I moved the load to the front of the trailer, it still had the same bounce. Maybe a little better, but it was still there and I could not go over 60mph for fear I would lose control.
hikeril; After you put the air bags in, you still had the bounce?
I think the shocks are what I need, I am going to look into the Rancho 9000's now.
Never too late. The more people that chime in and let me know that shocks are the answer the better I feel about spending all this money on them.
