leaking injection pump
Old Jul 22, 2012 | 11:24 PM
jeffu86's Avatar
jeffu86
Hi all, new to the forum so I apologize if this ends up being a repeat thread.
So I just purchased an 84 f250 with a 6.9L today. The only issue that I need to take care of is the fuel leak that is coming out of the return line at the front of the injection pump.
Do any of you know what kind of seal this fitting uses? Will I need to buy a whole rebuild kit for this?
Thanks!
Old Jul 22, 2012 | 11:35 PM
1989f250IDI's Avatar
1989f250IDI
Is it leaking from the 90 degree coming off the pump starting the return?
Old Jul 23, 2012 | 12:34 AM
jeffu86's Avatar
jeffu86
Yes the 90 right off the front of the pump
Old Jul 23, 2012 | 12:56 AM
NMB2's Avatar
NMB2
What are you calling the front of the pump.
towards the firewall, or towards the radiator?
Old Jul 23, 2012 | 01:04 AM
jeffu86's Avatar
jeffu86
Sorry for not being clear on that.
Front as in towards the radiator
Old Jul 23, 2012 | 01:18 AM
NMB2's Avatar
NMB2
ok, thats the back of the pump. if its leaking past the threads, pull that fitting out and use a liquid thread sealer, and put it back in.
Old Jul 23, 2012 | 01:30 AM
jeffu86's Avatar
jeffu86
Ok makes sense that the return line is at the back of the pump lol!
Thanks for the help!
Jeff
Old Jul 23, 2012 | 03:51 PM
jeffu86's Avatar
jeffu86
Well that was much easier than I thought! Once I finally put a wrench to it I found out that the fitting was loose.
I tightened it up and hopefully that'll do it!
nothercrash
Dec 31, 2024 05:13 PM
zombiesawyer
Nov 2, 2009 02:24 PM
hunterguy86
Oct 9, 2006 03:50 AM
GaryTOR
Jun 13, 2006 08:29 PM
General Davis
Aerostar
Oct 21, 2003 09:26 PM
