How important is a water seperator?
I noticed the other day that mine on the firewall had been bypassed. I Thought I had read that you could switch the fuel filter out with a combo from a newer year. Is that right.
Is it really needed. I know water does not combust or compress but how often is there water in the fuel? Is it from crappy gas stations?
That what I was thinking
I have been running my 6.9 for about 7 years now with the water separator removed and have not had problems (with water in the fuel), but I live in Arizona, so the climate probably makes it less-necessary here. That said, my rebuild will be using the fuel filter set-up with built-in separator from a 94 IDIT engine. Ford put those separators on there for a reason, and I would rather it was in place as long as it is not a chronic source of air intrusion.
branden.w
12-01-2009 10:47 PM
ExpySport
12-01-2008 08:40 PM
twotonestepside
01-26-2008 10:00 PM
