help on axel shaft, knuckle, ball joints
im curious do u halft to take the knuckle out the get the hole axel shaft out? or is there a way to not
and whats the best ball joints for a truck with a 4inch lift i heard something about XRF and moog but still aint sure, im about to be removing my front axel and breaking it down and how much of a pain are these balljoints to remove?
in a few weeks im taking my leafs out to be rearched and iv had this grinding noise for awhile i posted up here and wa told it was my hub bearings and that wasnt the problem the axel U-joints are good replacing them when i break it all down to check bearings and what not
will also need a list of seals and such i would need
please and thanks
please and thanks
It depends on the tools you have , if you have the rite tools its not to bad to do.
I have allways used Moog front end parts and thought they were the best, then I herd about XRF's, so I did a little reading about them and will probably use them next time I do some ball joints. The parts store I deal with stocks them, so I asked them to look at some and they did look real nice.
im curious do u halft to take the knuckle out the get the hole axel shaft out? or is there a way to not.
No!!!!!
Look here. http://www.superdutypsd.com/ball_joint_article.php
No!!!!!
Hound Dog Lew
05-12-2016 04:56 PM
