idle problem
There shouldn't be any EGR feedback at idle, so No vacuum on the EGR diaphragm vacuum line at idle is right/as it should be/ok.
The other suspect might be the vapor recovery vacuum switching valve leaking, or not seating/sealing well. So maybe try disconnecting it at the intake manafold connection point & plugging the vapor line & its intake manafold vacuum connection port, drive it & see if the misbehaving idle stops acting out. Could do the same for the EGR vacuum line & do a test drive. OR, when its in one of its high idle fits, pull & plug the EGR valve & vapor recovery vacuum lines, one at a time & see if you get any response.
Once the engine idles down, the problem seems to be mostly gone away, so it may be more difficult to locate.
Then Murphys Law may be messing with you & you might have more than one problem. With the IAC Disconnected, the engine idle should drop & the engine might idle rough or stall, yet it seems to go right on idling at 1000 rpm & when it does drop, its only to 800, so yes I agree it sounds like you have an unmetered vacuum leak somewhere & I agree with slc10844 that intake manafold gaskets belong on your suspect list.
So maybe break out your torque wrench & try re-torquing the intake manafold fastners to spec in a crisscross fashion & see if you find any loose fastners.
Was the PCV valve rubber plumbing parts ok, no dryrot, splits, or soft mushy connections??? Same for the DPFE hose connections below/underneath the EGR valve, where they connect to the differential pressure orifice tube ports. It gets plenty hot down there & those hoses tend to get baked out & become hard/split/dryrot.
How did the under hood vacuum reservoir & its vacuum hose trouble shoot go. The clue you posted about hearing the blend door pop closed is a good clue that you have a vacuum leak some where, so keep looking & testing as has been suggested by disconnecting & plugging vacuum lines, to isolate various vacuum operated systems & see how it goes, or disconnect lines & apply a vacuum with your mighty vac, or the like, to see if those vacuum operated systems will hold vacuum ok & not quickly leak off.
More thoughts for consideration, keep us posted on your trouble shoot.
