Aerostar Ford Aerostar
Steering column compatibility
Old Jul 19, 2012 | 07:25 PM
asavage's Avatar
asavage
FTE Community Team
Originally Posted by Jose A.
great technical info. Al. the famous pin/button few know about, some people think they have to lower or remove the entire steering column to replace the ignition switch and yet, it is so easy !!
It's only easy if you can turn the cylinder. If you don't have a key, the key is broken, or the lock is broken, the poke pin doesn't do you a whole lot of good.
what I do not see in your pictures, is a quarter-moon-shaped, brown plastic attachment with a copper or brass "leg" connected to a wire with a yellow jacket that is inserted into the 8 o'clock position of the switch. ??
You don't see it in this picture?
I didn't write that post to be a tutorial; that was just some info I stole quickly from this post about the weird shield on my 1997, which I could steal fast before breakfast and out the door to work. I don't have a good "installed" pic of the key minder contact & wire.
Originally Posted by mediaman67
great diagram, but this is the newer style - I have the older one, I guess they are similar...(the van is an 89)
Right, and I mentioned that, the very first line in the post is, "This lock is similar to yours, though the end & cover are different . . . ".
Yours has a rectangular end with no tit on one side, and the black plastic ears in that pic are the very latest style used on Aeros; yours are chromed pot metal instead of plastic. Here's some pics of your early, 10-cut ignition lock cylinder (courtesy NAPA; their part No. ECH KS6053):
someone thought it's the switch instead of the key cyl; do you have the switch connection to the key cylinder?
From what you've described, I would be scrutinizing the electrical switch, rather than the lock cylinder.
I think I've got a pic of the connector for the switch, probably tangentially. Gawd knows, I've surely had enough Ford ignition switch connectors off -- I used to install ignition interlock devices for DUIs.
Hmmm. Thinking about it, I may not have any pic for the pre-91 column. I'll look around.
It's on the left side of the column, and about halfway down IIRC. You'll have to remove the knee trim panel to access it.
Old Jul 19, 2012 | 07:58 PM
asavage's Avatar
asavage
FTE Community Team
Early Aero Ignition switches, 1986-91:
Stolen early Aero column pic from this thread.
Old Jul 20, 2012 | 04:52 AM
Jose A.'s Avatar
Jose A.
yes! I must have missed the picture.
Old Jul 13, 2013 | 07:26 AM
mediaman67's Avatar
mediaman67
Al, any chance you remember what torx size I need to remove those two bolts for the switch? I assume 2, since the metal bracket above is showing 2 holes
Thanks
Old Jul 13, 2013 | 09:17 AM
asavage's Avatar
asavage
FTE Community Team
I'm sorry, I do not. I have a couple of the
Lisle torx sets Lisle torx sets
(one at home, one at work) and I just grab the socket from the set, I don't usually look at the number.
Most Ford stuff falls into T10 (headlights), T15 & T20, then a sprinkling of T30/T35/T40. Having the set is helpful, and it's under $20 for the set. You do break them every so often, but I've had pretty good luck with the Lisle sets.
For the small stuff (T20 and under) I use one of
those cheap, small bit sets those cheap, small bit sets
instead. The security version is handy everywhere, but on the Aero specifically, I use them for the MAF. These sets are now generic and the non-security version can be found at hardware stores these days, for under $10. The security version shown below is sometimes harder to find retail.
Old Jul 13, 2013 | 11:57 AM
xlt4wd90's Avatar
xlt4wd90
Great information Al; thanks for sharing your professional knowledge.
Harbor Freight has kits of security bits like those you showed, and more, for low prices. I got a second set that contained really small bits, as I needed a t-5 to open up one of my laptops.
Back to keys: When I bought my 1990 Aerostar, I did not get the original keys, just duplicates, and I don't know how many generations (even though the van was only 4 years old at the time). The first time I tried to copy the keys took a couple of attempts with a standard key machine that you see at the local hardware store. Now, the key is loose enough that sometimes I can remove it from the cylinder while in the run position. But recent attempts to copy the key have failed to produce a working key.
When I worked for Ford some 30+ years ago, a guy on the assembly line could look at the teeth on the key and guess at the number of each landing, and used a hand cutter to cut the exact key I needed. Do lock smiths still do things like this, or do they have to take apart a cylinder to look at the tumblers?
My keys did not come with any of those metal tabs that had the key code on them, so they can't be remade that way either.
Old Jul 13, 2013 | 04:11 PM
mediaman67's Avatar
mediaman67
yes ditto Al, Im almost there...
Ok, got a new switch, I see it all in there now how it mounts, etc.. I think it will be the switch, since the old one sort of fell apart in my hand, and all that is left there is the metal housing for the whole unit (noted by comparing the new to the pieces I had in my hand lol - all that is ONE unit)
So, new problem - the heads of the bolts/screws are right up against that plastic guard... all that opens is the bottom "flap"...
do I have to pull the wheel to take the plastic piece off? - If I could just move it like 3 inches, I could get a socket in there...
I really don't want to have to pull the wheel - my old gal is starting to tease me a bit here, seeing the end of the rainbow, but not easy road to get there...
Any thoughts on access? I really didn't want to drill holes into the plastic... since I'm sure I can't get one of these anymore new on a 25 year old van lol
Thanks to all, (and esp Al)
Old Jul 13, 2013 | 09:43 PM
93nighthawk's Avatar
93nighthawk
I am not sure about lock smiths, be we have a gauge tool at work that you hold up to the key and it will tell you what cut each one has from 1-5. and you take the hand cutter and set each position to that cut. Knowing that the original key is worn down, I would step up each one 1 spot.
Worth a shot to stop by your local Ford parts room and see if they still have that tools and the knowledge.
Old Jul 13, 2013 | 10:08 PM
asavage's Avatar
asavage
FTE Community Team
As NightHawk said, there are "only" five depths for each cut, and ten positions. Yes, locksmiths do still "read" keys as you mention, though I have to say that a worn 10-cut key like yours is better "read" on an originating machine. What I mean is a machine that is normally used to cut a new key by translating the key code to a string of numbers that the indicate the depth for each position, something like (14534 43442) which would represent the depths of each cut (one to five) for positions one through ten.
Chuck up your old key in that machine, leave the power off, and crank the jaw to the first position, then crank the key toward the wheel until it just touches. Write down the closest depth from the indicator on the machine. Lather/rinse/repeat for the other cuts. The advantage of doing it this way is that the spacing is handled by the machine's setup: you don't have to guess which space you are trying to read the depth for. On a worn key, instead of discrete cuts, you have a continuous wave/slope between the cuts. You can guess pretty well on a five-cut key (most Fords before 1984.5) but on the 10-cut and 8-cut keys, it's just too easy to mistake position 5 for position 6 and so forth, because the positions are so close together.
Can a worn 10-cut key be read back to the depth string by eye? Sure. But I usually burn a couple of blanks trying to do it that way. If the key isn't too bad, I can use dial calipers across the double-sided cuts and get close enough to get it right on the 1st try, but if it's got a decade of wear . . . nah. Since I'm going to use an originating machine to cut you a new key anyway, I may as well use it to help decode the old key.
Now, if someone is using a nibbler or punch (what NightHawk is calling a hand cutter: a fairly inaccurate way of making a new key), you don't have that tool available to help decode. The slot gauge he refers to works great -- on brand-new keys, but again if you can't tell position four from six because of the wear, you're going to burn a lot of blanks guessing.
The last shop I worked for that did automotive locksmithing would charge about $35 to originate a key by decoding ($15 to cut by code). Other shops I've worked for had varying rates, but in no case should a reputable shop charge you more than $50. Most should be much less.
If your ignition cylinder is original, and since you have a working key, you might remove the cylinder from the column, wipe it down, and look for a four-digit code stamped on the outside of the cylinder. I don't think it'll be there, but it's worth looking. Could be four digits and a letter for Fords of that era.
If you take the key to a locksmith, it's best to drive the Aero to them, so they can try the key they make and re-cut it or cut another should it not work. Asking them to decode it from your worn key and not test it is asking for trouble; many won't warranty it that way. Take them the van, and they can cut ambiguous cuts high and read the impression if it won't turn. It's easy to fix that way, by re-cutting the same blank lower in the positions that leave an impression in the brass. That's what I do.
HTH
Old Jul 16, 2013 | 07:05 PM
ptbll's Avatar
ptbll
If you take the passenger side door lock it has the orinal key code. thats assuming the ignition key also opens the doors. the older ones tha has the round key is not the same.
Old Jul 17, 2013 | 07:58 PM
asavage's Avatar
asavage
FTE Community Team
That is not true of Fords of that era, IIRC. Mazda, Nissan, Subaru yes. Sometimes Honda. I've never seen a code on a Ford door lock though. I've had a number of them brought in to have a key made. Usually, my first question is, "Are you expecting the key that I make to fit this door lock, to fit the ignition?". If the answer is "Yes", I have to explain that while the key is 10-cut, the ignition uses cuts 1-6, the doors 5-10, so no one lock on the car will have enough information to recreate the entire range of cuts to operate all the locks. I can get within four cuts, but from then on it's guesswork. I have software that, given the known cuts from the disassembled lock, can print me a list of most-likely cuts to try based on the six I already know, using various rules-of-thumb about known complete 10-cuts codes, but it still involves burning several key blanks and a lot of recutting. And, of course, you have to have access to both locks at the same time, to try each attempt. IOW, it's usually a service call (field service) job, which automatically adds $50-100 to the job.
There are other methods of recreating a key that don't involve lock disassembling one or more locks, but the same problem exists: no one lock contains all the information needed to recreate the entire key.
It's not as easy as you might think.
akamacgyver
Jul 30, 2017 06:13 PM
f100beatertruck
Feb 16, 2012 09:28 AM
Avanti
1983 - 2012 Ranger & B-Series
Jul 22, 2006 05:18 AM
wsutooldude
Dec 5, 2003 11:17 PM
Chrisvte
1978 - 1996 Big Bronco
Mar 29, 2003 11:26 PM
