Bought a junkyard holley carburetor- dont know what rebuild kit to buy.
I bought a carburetor, came off a small block 80's model ford truck. There weren't any doors on it and no marking to which year it was, but it had an egr. I forgot to write down the vin.
The carb doesnt have a tag on it, just some numbers. Its electric choke vacuum secondary 4 barrel holley, single feed fuel. dual float bowls. Can someone help me figure which rebuild kit I should buy?
On the air horn its stamped B0476 and under that its 1217
The choke plate is stamped 410
Next to the air horn on the body its stamped 6R 5696 B
The metering plate?(the thing between main housing and primary resivoir) 10647
The accellerator pump is stamped 34r-2178b
Was wondering what size it was, and what rebuild kit to buy for it. I dont know how to look them up, and google isnt my sidekick! Thank you!
Holley Performance Technical Service Department
One of the carb guys may know more offhand.
Does it say anything like "Manufactured for Ford by Holley" on the front anywhere?
I didnt find anything that said list like on the other holleys ive had. I didnt find any other manufacturer name on it either.
Maybe these will help?
Holley is the only manufacturer ive found on it, though it is greasy.
I dunno if you can make it out, but this is where there are numbers on the air horn B0476 maybe 80476 i dont have good enough eyes. Below that number is another 1217.
This is next to the air horn on the main body. reads 6r(5696)B
zenmaster
11-27-2008 01:27 PM
SuperDutyDave
10-16-2004 07:51 AM
