door chime won't stop when I remove key.
Old 07-05-2012, 04:43 PM
gpeade's Avatar
gpeade
gpeade is offline
Hey folks what's up. Been a while since I last stopped buy but I knew someone here could help me. Recently the key chime will not stop when I remove the ignition key. It doesn't do it all the time but is getting more frequent. Usually I can reinsert the key and remove it once or twice and it will stop. Any idea how to remedy this issue? Is there something inside the ignition that can be repaired or am I looking at replacing the entire thing?
Thanks
Old 07-06-2012, 10:46 AM
bogeyrider63's Avatar
bogeyrider63
bogeyrider63 is offline
Trailering
subscribed, mine do's the same thing also.
Old 07-06-2012, 11:22 AM
gijim2k1's Avatar
gijim2k1
gijim2k1 is offline
Mine has done this a time or two, I've usually just put it back in, turned it part way then turned it back. I wonder if possibly a little WD-40 or something similar might free it up. It seems like something is sticking in there
Old 07-09-2012, 02:09 PM
gpeade's Avatar
gpeade
gpeade is offline
yeah I wondering if its something sticking or something failing. I will try the wd-40 and report back. Apparently it's something very uncommon with no more replys than this.
Old 07-09-2012, 10:49 PM
1969furd's Avatar
1969furd
1969furd is offline
why not just find the wire and disconecnt it?
Old 07-10-2012, 11:02 AM
Kentucky F150's Avatar
Kentucky F150
Kentucky F150 is offline
I have an 05 and it does the same thing, I have put graphite in it but that didn't help. I'm interested in what you guys come up with...
Old 07-10-2012, 02:07 PM
Pugnasty's Avatar
Pugnasty
Pugnasty is offline
Sounds like a circuit closed and stuck from when the key was in the ignition after you pull it out. I don't know what the fix is, but i would put money on that being the problem. The switch is probably getting stuck in the closed position when you pull the key out. Maybe a more electrical minded person here will know the fix for it though.
Old 07-10-2012, 04:16 PM
robertc1216's Avatar
robertc1216
robertc1216 is offline
I would stay away from spraying wd40 in there. Pretty sure there are electrical connections nearby. Mine has been doing it more often and i was thinking about using white lithium grease or something like it.
Old 07-11-2012, 07:49 AM
gpeade's Avatar
gpeade
gpeade is offline
No offense but I prefer to fix the problem.
Robertc, thanks for the heads up. I didn't realize there was an issue with WD and electronics. I think I have some electronic contact cleaner. Will try a shot of that instead.
Old 07-11-2012, 08:41 AM
1969furd's Avatar
1969furd
1969furd is offline
no offense taken
Old 07-11-2012, 08:14 PM
robertc1216
I am not positive you would mess anything up, I just don't feel comfortable getting liquid around connections the factory didn't think would get wet.
Old 08-11-2012, 12:54 PM
markford11's Avatar
markford11
markford11 is offline
I've got 3 trucks with this problem all ford and notice if you lift up or twist slightly on the collar with the key out it stops dinging. i think the switch is gummy or its worn out.
slowly getting around to cutting the wire on them.
(don't want that annoying feature anyway)
Old 08-12-2012, 09:06 PM
08FX4F150's Avatar
08FX4F150
08FX4F150 is offline
door chime malfunction
i had that problem happen today for the first time....keep us pdated on fix--please............
Old 08-12-2012, 09:07 PM
08FX4F150's Avatar
08FX4F150
my truck did it for the first time--keep us posted on fix......
Old 08-13-2012, 06:56 AM
ChrisCarter's Avatar
ChrisCarter
ChrisCarter is offline
Fix is taking your finger and hitting the key entry a few times... It eventually has quit messing up after I did this a lot.... not really a fix but my key in the ignition still chimes and it don't continue after removing the key. This took probably a few weeks of every time it would do it me taking my finger and giving it a good thump
Quick Reply: door chime won't stop when I remove key.
