Limited Slip Axle Question - Help please!
Old May 8, 2003 | 09:00 PM
TarheelNorseman's Avatar
TarheelNorseman
I am a new poster, although not new to forum. Have been checking out the threads for a couple of weeks. Seems like a lot of knowledgeable and helpful people here. I look forward to joining your community.
Here's my question(s). Am seriously considering purchasing new 2003 6.0 PSD Excursion 4x4. The Limited model that I want is now on the lot with the options I want, but the vehicle has the regular 3.73 axle instead of the 3.73 limited slip axle (a $250 option).
1) What is the difference?
2) Which is better? I don't tow now, but will likely be towing in the 7000-8000 lb range with this vehicle in the forseeable future on a every other weekend basis.
3) What should I buy? Considering not only my current and future needs, but potential future sale of the vehicle.
Not relevant, but I currently drive a 1998 Expedition Eddie Bauer 4x4.
Old May 9, 2003 | 04:56 AM
Monsta's Avatar
Monsta
Sit. Stay.
Originally posted by TarheelNorseman
... but the vehicle has the regular 3.73 axle instead of the 3.73 limited slip axle (a $250 option).
Welcome!
1. A Limited Slip or LS unit will split the torque evenly between the two rea drive wheels.
2 & 3. For just towing and no offroading and no real inclement weather to contend with, then go for the truck on the lot. The 4WD will help you enough with any low traction situation. If it were a 2WD though, my advice would be opposite.
Old May 9, 2003 | 10:19 PM
bstopek's Avatar
bstopek
Can I add limited slip to my Excursion? If so, what is the approximate cost and how difficult is it?
Old May 10, 2003 | 07:55 AM
Mark Kovalsky's Avatar
Mark Kovalsky
Frmr Ford Trans Engr
Originally posted by Monsta
Welcome!
That's not quite what a limited slip differential does.
A limited slip differential limits the difference in speed between the two rear wheels. If both wheels are on a high traction surface and neither is slipping the limited slip does nothing at all. The torque is split between the two wheels regardless if you have the standard axle or the limited slip.
If one wheel starts to spin the limited slip clutch engages and limits how much the spinning tire can spin by transferring torque to the wheel that isn't spinning.
Old May 11, 2003 | 03:20 AM
Monsta's Avatar
Monsta
Sit. Stay.
True. I gave a very (over) simplified explaination. Thanks for calling me on it.
Old May 11, 2003 | 11:30 PM
RRMike's Avatar
RRMike
Actually on the stock limited slip there are clutches between the side gears and the carrier that act at all times to provide friction between the two so that the side gears will turn with the carrier.
If one tire spins out the other tire will have only the friction of the clutch trying to drive that tire. The spinning tire doesn't make anything "engage."
The LS also does not limit the difference in speed between the two rear tires. That sounds more like a description of what a locker does although not an accurate one.
Old May 13, 2003 | 08:56 PM
Btravelen's Avatar
Btravelen
If it's not exactly what you want, you might consider ordering one. You won't pay any more for it, and most of the time, you can negotiate a lower price on an ordered vehicle.
Maybe not on the 6.0L though. They're not even offering the incentives on those.
It's hard to wait, but you would get what you want.
79F150EFI
Nov 6, 2013 06:29 AM
frankf
2009 - 2014 F150
Aug 3, 2012 08:26 PM
CATANG MOTORSPORTS
6.4L Power Stroke Diesel
Feb 27, 2008 11:13 AM
mcn420
Apr 15, 2004 07:57 AM
nafzimo
Sep 26, 2002 06:41 PM
