M5OD Shifter Fork Wear Diagnostics (Pics inside)
#31
Hope you get it figured out. Good luck. Sandy
I'm not arguing the point but I am curious and to why you don't buy it being the problem. I thought the forks ONLY rode in the sliders and never touched anything else. That is why I buy into them causing the wear. I guess if the sliders were sloppy from wear they could slide into the forks some but I am not sure.
#32
#33
IIRC your 1-2 fork was replaced soon after you got your truck several years ago. We don't know the habits of the PO. Have you replaced it since? Sandy
#34
#35
I think 1-2 fork wears more because you push the shifter harder to get into first gear from a dead stop. You push it harder because the first-gear synchro has to slow the output from 700 RPM (idle speed) to 0 RPM (wheel speed) before it can go into gear. The rest of the gears don't have as much of an RPM change between them. I guess technically you don't have to push it harder, you could just wait a couple more seconds for the synchro to slow the output shaft to 0 RPM. But I think most people just unconsciously push it harder.
Anyway, by pushing the shifter into first gear with more force, the fork pushes against the slider with more force. The slider pushes the synchro harder, which creates more friction and slows the shaft down.
Does that make sense?
Edit: The synchro doesn't just slow the output shaft -- it slows the output shaft, counter shaft, and input shaft. Basically everything in the transmission has to stop rotating before it goes into first gear from a stop. And the output shaft isn't turning at 700 RPM, it would turn at about 250 RPM because of the first gear ratio. Anyway, that is a lot of rotational energy that the first-gear synchro has to convert to heat (via friction) to slow the transmission internals to 0 RPM.
#36
I don't doubt that user abuse is a contributing factor to fork wear. My questioning was more specific with regard to leaving your hand parked on the shifter as an arm rest as a cause of wear. With as little time as the transmission stays in 1-2, I would think that wouldn't be the specific cause.
With my transmission, my bigger concern was that something else was going on that was causing the 1-2 shifter fork wear I saw in 2012. ~10,000 miles later, my inspection yesterday alleviated those concerns. In fact, I'm MORE inclined to agree with you now that user abuse was the cause given that under my care, I have not abused the transmission, and there is no 1-2 fork wear at all.
#37
#38
When I drained the fluid before dropping the transmission there was a fair amount of ferrous "goop" stuck to the magnetic drain, so I was a little concerned given that had accumulated with just 10K miles of use. I'm not sure how "normal" that is, but at least it's not a 1-2 fork about to fail!
#40
I suppose if the old 1-2 fork bent, that would have resulted in it wearing out in a hurry and would explain why the replacement one is doing totally fine.
#41
#42
I may not have mentioned it, but indeed I did change the fluid when I replaced the fork ~10K miles ago.
#44
A lot of folks on here have used Allstate Gear. Here is their website and the parts they have for our transmissions. If your shifter is sloppy, a shift kit is available also that is easy to install and gets the shifter back to normal.
https://www.allstategear.com/Manual-...rts-s/1815.htm
The following users liked this post:
#45
sandymane, thanks for the response. I bought the shift repair kit and 5/8 metal plugs from Allstate in an attempt to fix the oil leak from the shift tower. That's when I noticed how worn my 1-2 shift fork was, it's about .040" thick. The 3-4 is in better shape but I'm going to replace both when I'm in there.
The pictures of the shift forks on Allstate's website don't match what I have on my truck. The pictures of the OP's forks match what I have, that's why I asked for his part numbers. My truck is a 95 and I've had it for 2 years. I'm wondering if the original transmission was replaced at some time. I'm going to call Allstate on Monday and see what they say.
Here's my 1-2 fork.
VOTS
Here's my 1-2 fork.
VOTS
