Has this happened to anyone else?
Lately (within the last couple of days) when we park the Excursion we have a difficult time getting it out of park and into gear whether it is going in to Reverse or Drive the gear shift does not want to move. I have not forced anything at any time but eventually with some pumping of the brake pedal and some putting into park and out of park we can free it up. This is something that happened virtually overnight and once we are in gear everything is normal.
Has this happened to anyone else? If so does anyone have any idea what is causing it? I am making an assumption that it has to be some switch in the steering column but I am no mechanic and only guessing. If someone knows what this is can you please fill me in on it and what the cost is to repair whatever it is causing this?
Thanks in advance.
Thanks in advance.
Hey Buckeye Fan, Moved from Layton last year. In Hawkeye country now.
Try this post: https://www.ford-trucks.com/forums/1...l#post10468867
I really am not a sports fan, but I do like to poke fun at others weaknesses... such as the Buckeys. LOL
Actually I was born and raised in Portland, OR. Now that really IS God's country.
Thanks in advance.
Thanks in advance.
There are two bolts under the steering column above the brake pedal and main shaft of column, where the linkage goes together. The two bolts sometimes loosen up causing hard shifting from the column and will tend to not go into the gear your wanting. My thought is that you could have this problem or one of the two has come out completely. Good luck hope this helps!
precisiontile
03-21-2012 10:54 PM
villiano
11-29-2011 07:57 PM
